Question about General Electric WJRR4170GWW Top Load Washer
Washer fills and drains but won't aggitate or spin
Washer is less than a year old and just stopped spining suddenley
Posted by chlynmar1 on
  • tiggeroo432 Apr 18, 2009
    I bought a GE WJRR4170GWW and it didn't last two months before it the spin cycle stopped working. I had horrible customer service with GE and finally had enough and called the store where I bought it and talked the manager. He was awesome and went above the call of duty and just got me a brand new one with not a single problem! The new one didn't make it 18 months and is now doing the same thing!! Luckily I bought the extended warranty but it hasn't been fixed yet. To me something is not right here. Anyone else????
  • bawaldo Apr 21, 2009
    "2005 Washer fills and drains but won't aggitate or spin"
Anonymous
    President:
  • 373 Answers
Since the washer is less than an year old it must be under a warranty.Try contacting the customer care and get it replaced.
Generally for such a problem,the following checks need to be done.
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In your case I would advice to get your machine replaced with a new one.Good luck,Please do rate the solution if accepted.
Posted on Apr 10, 2009
I have a GE washer (WBB4500G2WW) - wont aggitate or spin
The BELT... Part number wh01x10302
30% of the time is the issue here:
http://www.appliancepartspros.com/ge-belt-wh01x10302-ap3968432.html
Have a look at appliance-parts-pros (video guide)
http://www.appliancepartspros.com/repair-help/general-electric-washer-wbb4500g2ww-repair/wbb4500g2ww-pumps-but-will-not-spin.html
May require a specialty tool to mount the belt
(depicted in VIDEO... Sold on site): view here:
http://www.appliancepartspros.com/ge-service-kit-belt-wx05x20641-ap5957260.html
((not entirely convinced the tool is critical but the
Also check prices on eBay (top seller, free shipping
WH01X10302 AP3968432 1264395 PS1482278 WH01X10353 Washer Drive Belt eBay
Hope this holds off trashing your three year old washer...
Carnac the Magnificent
My washer fills with water on starting a load but then it does nothing won't start spining to empty water
If the machine loads ups with water and does not stop then the water level sensor is fautly . But if the inlet valve stops on fill up but there is no spin of the motor or thereafter there is no spin/rinse or drain then the program controller / drain valve/pump must be checked.
Kenmore top loader washer aggitates but does not spin out the water it drains but no spining any ideas?
The spinning coil might be not received power supply properly please check it then check spinning coil if it faulty means kindly change the motor
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
2answers
Seven flashes means the washer did not sense a lid opening. Check the lid switch.
Spin cycles not spinning, does drain water before spin
check the wig-wag.it is the part near the cam bar.has 2 coils on it. also check the yellow wire going to the solenoid it may look ok but could be broke internally.
6helpful
3answers
Washer will not spin or aggitate
1. unplug for ten minutes.
2. plug back in.
3. open/close lid 5 times.
4. wash clothes!
General Electric WJRR4170GWW Top Load Washer Logo
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
