Below the drum is assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first is transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. if that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off.:) Open close the front door resets the code.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
