SOURCE: pioneer deh-p2000
turn off radio with ign. on-- depress source button for 3 sec. then function button for 3 seconds until clock appears--use arrow keys to set hours and minutes.
SOURCE: OEL Display not Working on my Pioneer DEH-P7800MP
Sorry can't help, but if you can't fix it and would like to sell it, let me know. I need the parts for an audio project I'm working on. Email: [email protected]. Good luck anyways :).
SOURCE: How to set a clock on a Pioneer DEH P2000 car
turn radio off and press clock then press function for about 4 seconds and the display will appear with the clock functions
SOURCE: i dont know wich wire is for what for Pioneer DEH-P2000
black ground red accessory (KEY) yellow memory constant power,blue is remote,orange is for the dimmer,green with black is left rear neg.and green is positive,violet black is right rear negative and violet is positive,white is left front positive and white with black is negative,gray black is right front negative and gray is positive
SOURCE: wiring my pioneer deh -p2000 to my speekers
Check the back of your receiver, to see the plug with a set of 8 wires that should have the following color standard:
Left front: White
Right Front: Grey
Left Rear: Green
Right Rear: Purple
Note: 1) Colored wires with a line/stripe on it is NEGATIVE, thus connect to negative on speaker. When connected, speaker cone should vibrate OUT, not inwards, otherwise reverse speaker connection;
2) You can check to see if speakers are in the right order by 'panning' balance and fader controls (from left front only to right front only, to right rear only, to left rear only in succession)
3)If there is an amplifier in your setup, the RCA plugs (like home audio plugs, should be connected instead, NEVER both!)
Hope this helps
Mark
