Question about Amana ASD2622HR Side by Side Refrigerator
Mfd2561hew frig not cooling properly. there's a whining noise every 2 or 3 minutes that lasts about 10 seconds.
1 Related Answer
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: It is making a buzzing sound
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Asker's Testimonial " Very helpful. Will give it a try and let you know outcome. Thanks!!! " - mibarra20605
Posted on Apr 12, 2010
1helpful
2answers
Whining sound jd 4510 four wheel drive
accord to my books this tractor has a wet clutch transmission (12 speed) , first thing is to ck your fluid level in transmission , this is bit hard to reach on this one but is possible second obtain a small sample of fluid from transmission, have it tested , It can tell you alot , second you mention that hydraulic pump overloads engine with simple tasks like raise 3-point, this could be a stuck pressure relief valve due to yep you guessed it dirty filter (it bypassed itself) ck hyd fluid for proper level and clarity ohh and one more thing this tractor uses hyd pump for power steering (some others have 2nd pump for this) is it possible that noise is coming from that area , cus I have had to replace power steering valve on that model once for a loud Noise reason
remember if your gonna have a all hydro tractor save yourself a lot of grief and periodly wash shaft seals with water sure saves a lot of grief and leaks !!
Whining sound
check the oil level
The display panel shows OF and now it's not getting cold in either the freezer or frig.
he letters "OF" on the display of your RS267TDRS indicate the Cooling Off mode has been activated. To cancel this mode, press the Lighting and Freezer buttons simultaneously for 3 seconds until a chime sounds and a numeric reading returns to the display, allowing you to set the desired temperature. The compressor should turn on in about 5 minutes and begin producing cold air.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Frigidaire refrigerator not cooling at times
Click this link below for problemRefrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
---------This will help.Thanks.
I have a noise, that sounds like a small motor is running about every 10 minutes that lasts for about 10 seconds then shuts down. It has been going on for about a week now. It has an icemaker in the...
Good day,
Sounds like an ice maker that is dry cycling. At least the timing you posted fits that profile.
If the machine is cooling properly, check to make sure the ice maker is turned off.
If the problem persists, please post back.
When our refrigerator kicks on, after a minute or two it makes this loud whining, from soft to loud, that lasts about 2 to 3 seconds and does it continually till it kicks off. It's like, Waaaaah, waaaaah,...
This sounds like a compressor that is whining. Or something maybe wrong with the fan motor. You can stop the fan to see if its still there. If it is then its the compressor making the noise.
6helpful
Refrigerator/freezer is warm, fan is running.
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
Noise from bottom of Frig
could be a solenoid going bad. these are usually located and the back rear of the unit, access it from behind (pull it out from the wall). take care .. it's energized with 120 volts AC. you can get a new solenoid unit at applicance parts places. OR solenoids could be okay and something (water or ice) is signalling it to actuate every 5 min.
3helpful
2answers
Whining Noise - hardrive or fan?
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Amana ASD2622HR Side by Side Refrigerator Logo
Top Amana Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
