I just bought this computer and wmp recognizes the cd but when i select a song to play it reports a problem and then shuts down. then the windows media center comes up and plays the cd fine. but it only does thhis when i insert the cd after i run up wmp. if i just insert a cd without running wmp first the windows media center pops up and shuts down.
Right click on your cd rom drive. Click on properties, then, autoplay>Select Music cd from dropdown menu. then select "take no action" for disabling WMP popup , if you have another cd player software, choose it to make that popup when you insert cd.
Sorry to say, That wonf fix your WMP but the problem. And sorry, there is not enough info to help you on WMP fixing.
I would like to suggest that you attempt to download & install the codecs that your media player requires, before it will play a DVD.
I found this typical when I was using the Vista operating system with Windows Media Player 11.
The codecs can be found as freeware online & a good site for the apt codecs for WMP 11 is @ www.majorgeeks.com once you are on the site, click multimedia on the left of the page, then scroll down to the codecs required.
The K-Lite series of codecs seem to work well with WMP 11 on Vista.
I truly hope that this has resolved your problem, as there is nothing better than watching a fine movie on the old PC.
Failing my advice, you could always 'Rip' the said movie to your media player & view it from your hard drive.
Good luck anyway.
Warmest regards,
Ste
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
Hi Janworks4u. Question for you... Did your mp3 work fine with WMP 10? I ask because WMP 11 is known for causing problems w/mp3 players. You can try reverting to WMP 10 to see if that fixes your problem. To do this:
click START, click on CONTROL PANEL, ADD OR REMOVE PROGRAMS (look at the top center of the Add or Remove Programs box that pops up for a little square you can click on that says "show updates." Click that box and then scroll down to WMP 11. Click to change/remove. A box will pop up confirming that you will revert to WMP 10. NOTE THIS WILL NOTE DELETE ANYTHING FROM YOUR COMPUTER! All of your music that is in WMP 11 will still be there in WMP 10!
Now you can try to load your songs back on through WMP 10 and hopefully it'll work for you. Good luck!
Apple late Thursday posted iTunes Repair Tool for Vista 1.0, a software update that fixes iTunes issues reported by new Windows Vista users. According to widespreadreports, music purchased from the iTunes Store could not be played in iTunes on the new Microsoft operating system released this week. Users reported that they received a message saying their computer was not authorized to play the purchased tracks. “The iTunes Repair Tool for Vista 1.0 will repair permissions for important files required by iTunes to play your iTunes Store purchases,” Apple states in the brief release notes.
yea it is compatible with WMP...it sounds like you are having some firmware issue...what I will recommend you to do is to get the latest firmware for the device...and make sure you have the device in MTP mode..once you have it in MTP mode WMP should recognize and you shouldnt have any [email protected]
player has problems with windows media player 11. works with wmp 10. player also has problems with vista. firmware was designed for xp. no firmware updates available. you can try dragging and dropping through windows explorer, treating it as a usb mass storage device. it will play folders and songs this way. to get vista to recognize it, format the player through the player's menu ( set-system-format ) not through the computer. take out the battery for 15 minutes. reboot your computer. put battery back in. plug into usb port. hopefully vista recognizes it as usb device
