I have a bad Brother HL printer and want to take out the drum cartridge to use in another printer. How do I take this out?
I have 'reused' the same drum three times and still prints like a charm.
Open the toner door and pull out the toner/drum assembly. Take the toner off the drum tray. Use a alcohol pad or lint free cloth and wipe the mauve coloured drum to remove the excess lint and toner collected on the drum. Rotate the drum with the white gear and keep cleaning until the whole drum is done.
Put the toner back in the drum tray. Clean the corona wire by sliding the blue tab back and forth 3 or 4 times. Put the toner/drum back into the printer and close the door.
After the printer does the self test the drum light will cone on again so then you need to reset the counters.
Open the door again
Hold the GO button until all 4 lights are lit up
Release the GO button
Close the door
Printer will self test and should extinguish all the trouble lights.
SOURCE: brother hl 2040 drum unit assembly installation
I was trying to put it in the wrong side of the printer!
SOURCE: Resetting the counter for Brother HL 2040
wecan reset brother cartage 2ways. when we are filling at that time we can adjust white ringe of cartage. otherway after reffiling . and when we put cartage in side the printer. we should push white and black point and start the printer .then it wi be reset.(it is tech. private methode)
SOURCE: HL-2040 Laser Printer: Brother HL-2040 Laser Printer Dos printing...
use PRN command to print
