Acer Aspire One  PC Notebook Logo
Anonymous Posted on Aug 26, 2013
My acer aspire one d225e wont boot up and says intel undi, pxe-2.0 (build 083) copyright (c) 1997-2000 intel corporation for atheros pcie ethernet controller v2.0.2.2(03/31/10) check cable connection! pxe-m0f: exiting intel pxe rom. no bootable device -- insert boot disk and press any key
leos1974138
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 74 Answers
  • Posted on Dec 10, 2013
leos1974138
Contributor
Level 1:
New Friend:
Cheetah:
Answers
74
Questions
0
Helped
4943
Points
80
U try to install a new operating sytem and u removed the cd from the drive so u need to burn with an ISO new operating system
This is what mine says when I turn on Intel UNDI, PXE-2 . 1 (BUILD 082) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check cable connection..
You hard drive is missing from the system. Just does not recognize it.
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Why won't my laptop load windows 7 when turned on? All I get is a black screen with acer on it.
Need to have the hard disk checked. The computer is not finding the operating software to run. This is found on the hard drive. Hard drive is bad.
1helpful
How do i fix a black screen when i can't log on to my dell n 4030 notebook
your harddrive (hd) isnt working properly or not fitted in hd-place right.
many hd's have really low life expectancy.
Acer aspire 5517 as no bootable device
Go to the bios setup and see if there are any HDD installed. If no remove HDD from laptop then put it back, restart then go bios setup again and see if it is installed. If still not, you might need to replace your HDD with a new one.
Hi i just switch my laptop aspire 6920 on and its start beeping and then its show me Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel Corporation For Atheros AR8121/AR8113 PCIE Ethernet...
enter to bios setup and remove Ethernet controller from boot sequence or make it last on the list. and about operating system not found if you already use your system without problem then reinstall the system from a cd .
When I turn on my laptop it goes to a black screen that tells me... Intel UNDI, PXE-2.0 (build 083) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller...
based the message that you encounter, it may pertain to boot priority or to BIOS configuration.
My recommendation is for you to access and reset the BIOS settings on your computer.
ACER first it said this ntel UNDI, PXE-2.1 (build 082) Copyright (c) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.13(2008/10/15) Check cable connection..! PXE-MOF:...
Press F2 on boot. go to bios, ie insydeh20 setup utility. goto boot menu. select legasy in type. select your usb drive and hdd as a first boot device. save and reboot.
When i turn the power on on start up it goes to a black screen and says intel UNDI, PXE-2.1 (build 082) copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller...
You get this kind of message when the laptop could not identify that there is a hard disk drive installed inside the laptop. Check your hard drive & make sure it is not dead.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
