Question about RTO Pelouze Scale With Remote Display - 400-Lb/180 kg Capacity
Calibrate pelouze 4040 scale. digital with 400lb capacity.
Posted by garylsuknigh on
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 59 Answers
  • Jeremy Mar 26, 2016
    I can't find anywhere on that site that explains the calibration procedure.
How to calibrate rubbermaid 4010-88 digital scale
Pressing the ZERO button will set the display to zero.
Here is the Spec Sheet
http://www.rubbermaidcommercial.com/rcp/products/detail.jsp?rcpNum=4010-88
If you think it is no longer accurate you would have to get an engineer in to reset it. Here is the Calibration Certificate.
http://www.rubbermaidcommercial.com/rcp/ObjectServer?table=PDFs&id=660
Dec 29, 2015 | Rubbermaid Pelouze 4010-88 150 lb. Digital...
Envelope postal scales by pelouse
go to a tobacco shop or a tobacco pipe shop"head shop",or ebay, Vintage Pocket Hand Held Postal Scale 0 2oz ,or here, Postal Scales Hand Held Scales , or, Items found similar to Hand held pocket postal scale keychain 100 grams... good luck,most staples will not sell them because they are commonly used to weigh drugs.
May 21, 2014 | RTO Pelouze Scale With Remote Display -...
Fix my pelouze fs6 scale
Based on its appearance I'm guessing that you need to unplug it and open it up. Clean it as well as you can with a stiff brush and an electronics safe cleaner. Roaches are the most likely cause of your scales failure!
All the above may be fruitless, it may not be possible or worth the cost to repair.
Time for a new scale! You must keep it clean and turn it off and disconnect it when you aren't using it. Roaches like warm damp dirty places!
Apr 03, 2014 | Health & Beauty
Ozeri ZK 14, error code oVE2, what does it mean?
oUt2 means that it needs to be calibrated. I am not familiar with these scales so no sure if they can be re-calibrated.
Jan 25, 2014 | Ozeri Pro II Digital Kitchen Scale in...
I need user manual for the Pelouze Model PE5 postal scale capacity 5 lbs?
If i were you i would try to search for it on google or look on their website.
Oct 19, 2013 | Computers & Internet
What is an E1/
see the relationship between the E-carrier system, the T-carrier system, and DS0 multiples, see digital signal X. E1 (or E-1) is a European digital transmission format devised by the ITU-TS and given the name by the Conference of European Postal and Telecommunication Administration (CEPT). It's the equivalent of the North American T-carrier system format. E2 through E5 are carriers in increasing multiples of the E1 format.
The E1 signal format carries data at a rate of 2.048 million bits per second and can carry 32 channels of 64 Kbps* each. E1 carries at a somewhat higher data rate than T-1 (which carries 1.544 million bits per second) because, unlike T-1, it does not do bit-robbing and all eight bits per channel are used to code the signal. E1 and T-1 can be interconnected for international use.
Mar 22, 2010 | RTO Pelouze Scale With Remote Display -...
New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Jan 16, 2010 | Jobar International Idea Works Wireless...
When powered up the display reads 4040 and will not display anything else. buttons don't seem to function
We solved this hold down the lb/kg button and the zero/hold and the on button at the same time up comes a A-of and then do it again and it will come up CAL wait a momment and then turn off and it will go back to zero.
Nov 18, 2009 | RTO Pelouze Scale With Remote Display -...
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
PELOUZE 4010 SCALE READOUT FAILED
my pelouse when i turn it on it stays on 0.0 when i put weight on it stays on 0.0 it then goes of i need help to get it to work
Jan 28, 2009 | Office Equipment & Supplies
RTO Pelouze Scale With Remote Display - 400-Lb/180 kg Capacity Logo
6,419 people viewed this question
Top RTO Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
