Sunbeam 4816-9 Food Processor Logo
A
Anonymous Posted on Aug 25, 2013
Where can I find le chef food processor bowl 14-11, 141A?
4 Related Answers
Jaime Hernandez
  • 2351 Answers
  • Posted on Jan 21, 2008
SOURCE: Sunbeam Food Processor/Le Chef 14-11, 14-1A
Check this website: //http://www.householdappliance.com/food_processor_parts.html
Anonymous
  • 13 Answers
  • Posted on Jan 19, 2009
SOURCE: I need large capacity processing container for my Le4 Che4f Food
http://products.howstuffworks.com/kitchenaid-12-cup-food-processor-kfp750-review.htm
Anonymous
  • Posted on Mar 26, 2009
SOURCE: cannot get food bowl off the Oskar food processor
My Oskar has two locking teeth on the bottom of the bowl. One at the 3 o'clock position and one at the 9 o'clock position. Grabbing the bowl at the bottom with one hand (using thumb and one finger), I twist clockwise (to the right) about 1/4 inch and the bowl unlocks and lifts off directly. (my unit's spindle doesn't have anything to do with locking the bowl. My unit must be 15 to 20 years old btw)
eyecam
  • 100 Answers
  • Posted on Mar 19, 2010
SOURCE: Looking for a manual and replacement parts for a
you can post this item usually on Ebay or search engine on the internet of a pdf file might be a small charge , if you need it mailed instead...>^.^<
My brand new Breville Wizz and Store Food Processor - LFP460 food processor won't start. The spindle is locked in and the bowl and lid are aligned and locked.
Question edited for clarity, full maker and model.
Question moved from Cars and Trucks.
With no blade and no bowl on the base, press a small screwdriver into the hole that is the safety interlock. Then try and turn the processor on. If it works, the problem is the bowl and lid lock. If it doesn't, the problem is the base and it is faulty.
https://www.google.com/search?q=LFP460+food+processor
2answers
How to take out stuck chef bowl
I've not seen a bowl stuck on one of those unless the chopping blade is jammed on the shaft and preventing the bowl lifting up. Or is the chef bowl a smaller bowl that fits inside the main bowl?
Kitchen aide chefs chopper Model KFC3100ER2 does not always turn on when pulse button is pressed
You need to replace either the bowl or the lid. Either the lid is not pushing the bowl mechanisms far enough or there is too much lost movement in the bowl part.
My chef chopper bowl has a crack in it would like to find a replacement bowl model KFC3100CA
Go to http://www.appliancepartspros.com/ and search by model number. They have everything you need at good prices. They have saved me lots of $$$ on various replacement parts as they are usually the cheapest because of tax and shipping. Hope this helps!
1helpful
I have a robot chef food processor it says type RC3 on the bottom the clear plastic top about 20cm dia with the funnel has broken where can I get a replacement part please?
To the person wanting a funnel for her robot chef just bought an old processor on eBay to replace the bowl I've got the lid if you still need it
I acquired an old Sunbeam Food Processor Le Chef without a users manual. How could I acquire one.
I was not aware that they came with manuals.. you might try talking to chefs or restaurant owners,i.e. other people in the field of food processing.
2helpful
3answers
My mom gave me her Le Chef that had several cracks in the handel and also the place where the handel attaches to the bowel with a screw was broken. I Used Loctite super glue for the crackes in the handel and a loctite epoxy putty that can be molded into the shape needed to fix the place where the screw attaches the handel to the bowel. After the putty set I sanded it to refine its shape and matched the screw hole in the bowel with the handel then drilled a small polit hole in the handel. I slipped the handel into the slot in the bowl and attached it with the screw and now I have a good as new Le Chef.
6helpful
4answers
Top Sunbeam Food Processors Experts
ZJ Limited
ZJ Limited
Paul Carew
john h
Are you a Sunbeam Food Processor Expert? Answer questions, earn points and help others
