First my washer would stop working after the water fill in now it fills with water through the entire cycle until the spin cycle. it never agitates or stops running water
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
Mar 12, 2005 - 10 posts - 3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
If water stops filling when you disconnect the washer:
Change the pressure switch.
If water keeps coming in after you disconnect the washer:
Change the water valve.
I would pull the 120VAC power cord to the washer for 10 seconds then power back up. See if you can get into service mode.To enter Service Mode press and hold he Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”.If you can’t get into Service Mode I feel you have a Control Board issue/failure.
If you can get into Service Mode then go to page 15 of the SM and we want to try a Quick Service Cycle test.Follow the instructions to enter the Quick Service Cycle test and let us know the results.If the test will run it will take about 10 minutes. Link to Service Manual for reference. Sears Parts Direct for reference. Rich
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it. Good luck!
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
On some models, the drive motor is universal meaning the drive turns clockwise in wash mode and turns counter clockwise in spin mode.
Possibly the motor windings is defective for the wash mode and thus the entire drive motor will require replacing.
Hope this helps..
