Hi Friend,
You Computer and Graphics card all things is good configuration. Some tips you follow.
A> If you PC virus infected then slow down you PC.
B> RAM memory increase because high HD game not support or slow speed problem.
C> Check you internet speed connection, because you are live game play.
D> And finally not solved then you re-install windows and again all driver proper install.
I hope solved you problem.
SOURCE: How to tell if computer hardware will be sufficient for Flight Simulator X
As per Radeon, they are stating that:
The Radeon™ 9250 provides the perfect balance of advanced 3D graphics, an enhanced multimedia experience and multi-monitor support, at a great price point.
At-a-glance:
So, if they are true, then it should be work...........
Thanks
Iqbal
SOURCE: I have a Dell GX620 Optiplex. The DVD will not
I think what TENNHICKS200 was trying to say is unplug the cd/dvd drive from the motherboard either sata or ide (i think it's sata for 620) into another sata port. depending on which form factor you have, you may only have one port for both hdd and cd/dvd. if this is the case (1 port for each) swap the sata ports and see if the hdd is being read in the bios before you boot to windows. if the cd/dvd drive is being read in the bios and is not burning in windows, then my friend, you have a defective cd/dvd drive.
SOURCE: Windows 7 drivers for Optiplex GX620
for drivers u visit driversdownload.com, register and then dowload required drivers for ur comp. i doubt ur computer is affected with virus. pls check it also
SOURCE: Hello, I just installed an
Go to Dell.com and check for new audio drivers. Download the newest versions of the audio drivers and your audio should work.
SOURCE: Dell Optiplex GX620 not recognizing PCIe video cards
1.make sure that the video card that you use is really working
2.make sure that you connect the video card first before installing.
then after you connect the video card wait for the popup at the lower right of the screen then when you see a pop up that says driver not installed the put your installer then after installing the computer must be reboot or restart for you to be able to use the newly installed video card. if that still did not work send back your video card it my be static or it may not be compatible with your computer. but if the video card work try this, right click on the desktop then you will see the graphics card name if not your video card is not properly installed or broke. send me a message for more info.ty
