SOURCE: computer restarted unexpectly or encountered an unexpected error
Seems like the preinstalled image is corrupt or there is a hardware problem. Contact Acer for the correct procedure since this is a new system. I could offer alternate methods if you have the Windows install disc, but it is best to contact the manufacturer as soon as possible so it is on record.
SOURCE: computer restarted unexpectedly or encountered an
Please explain the error. Mostly its because Windows couldn't access some particular area in RAM.
SOURCE: Acer Notebook was getting slow
A scratched cd/dvd can have errors causing the install to fail. Use a clean cd/dvd install disc to fix it.
If you are trying to install directly from the hard drive then a malware infection could have corrupted or damaged that part of your hard drive. Install windows from the cd/dvd disc for your computer.
SOURCE: My acer aspire wont start up due to restoring now
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
If this does not fix your problem then re-installing Windows is the best solution.
