SOURCE: how do i use my new sandisk cruzer?
insert the flash drive into your computer and wait for it to be recognised by windows. Once it has been recognised and installed it will tell you that it is installed and ready to use.
The just go to wherever it is on your computer that you have your photos stored, select your photos right click and click on copy, then go to 'my comptuer' and double click on your flash drive to open it and paste your picture there.
Or select your photos, right click, select sent to:- and send to your flash drive, it may be recognised as removable storage.
SOURCE: how do i transfer files to a SanDisk Cruzer flash
It is simple. You insert it into a usb 2.0 port on your computer. Windows will recognize it and it will show in the My computer window. You click on the icon for the drive and you can explore what is in it.
1.
If you have files (documents, pictures, etc.) you select them, right click mouse button to copy them ( CTRL C) then you open the Cruzer and you right click inside the drive window ( CTRL V) and click Paste.
.2. You can open 2 windows side by side, one for the folder that contains the file to be transferred, the other for the Cruzer. You will have to reduce the sizes of the windows. Then You click on the file to be transferred and maintain the click. After that you drag the mouse cursor and drop it in the Cruzer window. (That is called Drag and Drop)
Hope it helps.
SOURCE: I have a cruzer micro 16Gb flash drive with 14.9Gb
Did you reformat as NTFS instead of the default FAT32? FAT32 can only transfer files up to 4.0Gb in size. If you reformat as NTFS, you can move larger files.
SOURCE: Sandisk U3 Cruzer Micro 8Gb Cant Format :S
rite click on it in mycomputer and click propertys to see if your thunb drive even has memory on it could have ben fried by sum and has no memory now
SOURCE: how do you reset the sandisk Cruzer Micro 4GB USB
go into my computer, rightclick the drive, click format, select ntfs or fat 32, give it a name, use quick format and click format again.
Testimonial: "Wow that was easier than I expected thank-you very much willell."
