Question about LG M4201C-BA 42 in. HD-Ready LCD
My 42lh30 lg tv was on the kids where watching movie on xbox then the tv and xbox just turned off. and will not come back on. the xbox is working. but there is no red light saying the tv is getting power. have tried different plugs and letting it sit to see if it was to hot sill no luck? Help
Posted by amber bowles on
David Low
  • LG Master
  • 458 Answers
Possibly you've had a power cut & a fuse associated with the TV has blown. Have you checked the fuse in the TV plug? If that's ok then probably a fuse internally in the TV has blown or something more serious has blown in the power supply
Posted on Aug 28, 2013
5 Related Answers
Anonymous
SOURCE: LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Posted on Apr 22, 2008
Anonymous
SOURCE: Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Posted on Apr 29, 2008
Anonymous
  • 197 Answers
SOURCE: tv won't turn on - power SUPPLY OK
bad main pcb
Posted on Jun 07, 2009
Anonymous
SOURCE: Won't turn on
There is a problem with main supply board .The electronic part called capacitor 2200uf 10v .There are 4 of them on that board when they all get defective thats where the problem is.Want to know more can email me.
Posted on Jun 22, 2009
Anonymous
SOURCE: my lg tv (model number 42LH40) won't turn on
There might be an off on switch under the lower right hand corner of the set. (feel for it) and switch it.
Posted on Feb 13, 2010
Hooked up Xbox 360 last week, now can't watch movies.
turn off parental controls on x box and tv if they are avalible on your tv. then you can watch any movie you want. go to menu then system set and you should see parental controls there. hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_e9d0abd7cc2508b3
4helpful
Replacement screen for a LG 42lh30
hello, you can the screen from the below link. tries websites like Shopjimmy.com,Ebay.com to buy a whole screen for the replacement.
Good luck...
3helpful
LG 42LH30 Audio Problem (Background Buzzing)
Ur power supply board.Transformers have have high voltage gap.This problems must take the tv aparts put some glue arond the transformers,sometime solved this problems,or must replaced all the trnsformers make the humming noise.Brand new tv take it back,where u bought it get a replacement or call the Manufacture help to fix the problems or replaced the part that cause the problem.
1helpful
Audio sync problem with LG 42LH30 LCD TV, TV is hooked up to HDTV PVR, problem occurs with HD stations
Contact your LG dealer first as the software version of your TV would need to be checked. Most likely the software needs updated which can only be done by a service engineer.
LG M4201C-BA 42 in. HD-Ready LCD Logo
Ekse
