Question about Hamilton Beach Water Cooler with Storage Cabinet
Need manual for grainger point of use water cooler # 2nu46
Posted by Waldon Richardson on
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
Water in engine oil.
water can get into the engine oil from several points
if the engine has a sump oil cooler hen the cooler coil wil be cracked or corroded at the seal points
more likely the housing behind the water pump has corrosion in it behind the impeller and water pressure is making it leak into the sump
May 18, 2015 | Seloc Mercury Outboard Engine Repair...
Need a manual for a Dayton Model 2YU40 electric heater
Contact Grainger
http://www.grainger.com/product/DAYTON-Convection-Ceiling-Heater-2YU40
Grainger owns Dayton manufacturing
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 05, 2014 | Water Heaters
I have a Dayton time switch hot water heater timer model 2E214 7 day timer in a house that I just bought. Don't really understand how to use it. Where can I find a manual or user guide? Or can someone ...
1) Dayton 2E214 timer is Grainger number for Intermatic 7801B timer.
http://www.grainger.com/Grainger/INTERMATIC-Electromechanical-Indoor-7-Day-2E214
2) Grainger page also show extra on-off trippers for the timer
3) Same/similar timer shows for water heater on following link:
http://waterheatertimer.org/Boxtype.html#T7400
4) I have a similar manual in my files:
http://waterheatertimer.org/pdf/t7802b-2no-2nc.pdf
5) Intermatic site is offline this weekend but link to iNTERMATIC manuals is following:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/7%20day%2040%20amp.aspx
6) If link above does now show exact product, then type Intermatic model number into search bar, and it will show manuals.
7) To operate the timer, attach silver and gold trippers to face of dial. See image below of Intermatic 24-hour dial.
The trippers are labeled on and off.
Buy more trippers at grainger if needed.
ON tripper pushes lever that closes circuit and turns water heater ON.
OFF tripper pushes same lever other direction that closes circuit and turns water heater OFF.
Dial rotates as time passes.
To set current time, rotate dial until current time lines up with pointer. The pointer is stationary.
I believe this model has to be reset after power outage.
8) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Kitchen Ranges
Timer will not turn water heater ON at set time, has to be done manually. However, it will turn water heater OFF at set time.
If this is new installation, check wiring. Hot and Load wires might be reversed.
Check that ON OFF trippers are both attached to yellow dial.
http://waterheatertimer.org/How-to-wire-WH40.html
If timer worked fine before, and started missing recently, then tripper pins probably worn out.
Trippers contact mechanical lever, and push lever on-and-off.
Trippers are softer metal and designed to wear out before lever.
If lever is worn out, timer needs to be replaced, but try new trippers first.
Buy trippers at Grainger
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How WH40 timer works:
Clock motor rotates dial.
ON-OFF trippers on dial contact lever.
ON tripper pushes lever one direction.
OFF tripper pushes lever other direction.
Lever moves electrical contacts together, or pulls contacts apart.
When lever moves on-and-off, manual override lever also snaps back and forth with audible clicking sound.
Using q-tip, add touch of white grease to lever where trippers contact.
Nov 25, 2010 | Intermatic WH40 - Water Heater Time Switch...
The timer is used on an Electric Point of Use 2.5 water heater. Currently I get hot water only about two hours in the evening. Before it was --on demand. I opened the timer box and one of the timer box"...
No overcharges here Ms bernarda
If I understand correctly you have Intermatic timer with a yellow dial
You have the Intermatic timer hooked to a small 2-1/2 gallon point-of-use water heater
Your point-of-use water heater is working fine
The timer turns on the water heater once a day instead of twice a day
And it seems like one of the tripper pins has fallen off the yellow dial
The tripper pin is missing and you can't find it or put it back.
You can turn off the electricity and poke around the bottom of the timer box and see if tripper pin can be pulled out using tweezers
Do you know Grainger sells Intermatic tripper pins for $1.67 plus shipping?
Now, if this is not the right answer, you post a response and we can probably help
Oct 21, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
There is power to the unit but the clock does not rotate. The unit is about one year old. It has to be turned on and off manually.
There are two possible answers:
First, does the timer receive 240 Volts from the circuit breaker? If your 240 Volt water heater heats water when timer is manually switched on, then the answer is yes, and the 240 V circuit is fine.
If the timer is not getting 240 V, it can still appear to have power if 1/2 of the 240 volt breaker is sending power, but the other 1/2 of the breaker is defective. You can test the breaker with a tester, or by moving wires to another breaker of the same size.
The second possible answer is that the clock motor is burned out. WW Grainger sells a replacement for $16. Clock attaches with 2 small screws.
Here is link to Grainger:http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
Here is a photo of back of WH40 showing clock motor:
http://waterheatertimer.org/images/Back-of-WH40-3-850.jpg
Sep 04, 2010 | Electric Intermatic Inc Wh40 Water Heater...
Motor is frozen.
Unlessyou can find an HVAC shop with a NOS motor for this unit you will notfind a drop in replacement. Even if you do get lucky and find a NOSmotor be prepared to pay nearly as much for it as you would a whole newevap cooler.
That said, there are motors out there that will work, but you're going to have to make them fit with custom mounts.
It'sstill a little spendy, especially if you want two speeds like theoriginal motor had, but you can get out for $80 or less if you'rewilling to settle for one speed (on/off).
boatandrvaccessories.com has a "Packard 40066" compressor motor for $69 plus $13 shipping. It may work but has only one speed.
Basicallywhat you're looking for is a "48 frame", 1/8 hp, direct drive,110-120v, 1075rpm, 1/2" shaft diameter and around 3" in length (to giveyou flexability when mounting), "totally enclosed" or "open drip-proof"housing (NOT "open"). Rotation can be either CW or CCW as you can mountthe motor on either side of the housing and some motors are reversable.If you've got the skill to custom make some mounts then you canprobably fudge some of these specs. The ones you can't change are the1/2" shaft and the RPM. Do not exceed 1075rpm. The blower assemblysimply can't be made to go much faster in that housing and if you tryyou will overheat the motor and burn it out very quickly (trust me onthis one!). Most of the cheap motors I've found are 208-230v and I justdon't see the point in having a small 220v PORTABLE evap cooler, that'sjust dumb.
After a LOT of online research I've found thefollowing motors that would be a suitable replacement, with all theabove mentioned specifications. I'm sure there are more, but crossreferencing this information for someone not in the business is trickyand time consuming.
AdobeAir 1/8 HP 115V Motor for Adobe MMB10A RF031095 $116.66
http://www.comfortgurus.com/product_info.php/cPath/25_142/products_id/7451
Emerson 4856 (k055srj4796722b) (www.emersonmotors.com)
A.O. Smith 136A (UH1036NB) (www.aosmithmotors.com)
Magnetek 136 (now owned by A.O. Smith - www.aosmithmotors.com)
Fasco D733 or D261 (fasco.com)
Marathon X924 (www.marathonelectric.com)
AdobeAir RK232A check acehardwaresuperstore.com
Emerson K55HXKZT-9867
Grainger.com is a good resource but they are expensive.
The motors listed are suitable replacements, but have only one speed, "ON" or "High".
Packard 40066 - 115v 1075rpm $69 - SINGLE SPEED
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Good reading for selecting a replacement motor:
http://www.aosmithmotors.com/WorkArea/DownloadAsset.aspx?id=13100
Isuppose that if you found a smoking deal on eBay for an "Open" typemotor you could try it, but I doubt it would last long and make damnsure that ****** is grounded well.
Jul 17, 2010 | AdobeAir Evaporative Cooler Direct Drive
I need a 1/8hp 115v 1075 2sp swamp cooler motor
Unless you can find an HVAC shop with a NOS motor for this unit you will not find a drop in replacement. Even if you do get lucky and find a NOS motor be prepared to pay nearly as much for it as you would a whole new evap cooler.
It's still a little spendy, especially if you want two speeds like the original motor had, but you can get out for $80 or less if you're willing to settle for one speed (on/off).
Basically what you're looking for is a "48 frame", 1/8 hp, direct drive, 110-120v, 1075rpm, 1/2" shaft diameter and around 3" in length (to give you flexability when mounting), "totally enclosed" or "open drip-proof" housing (NOT "open"). Rotation can be either CW or CCW as you can mount the motor on either side of the housing and some motors are reversable. If you've got the skill to custom make some mounts then you can probably fudge some of these specs. The ones you can't change are the 1/2" shaft and the RPM. Do not exceed 1075rpm. The blower assembly simply can't be made to go much faster in that housing and if you try you will overheat the motor and burn it out very quickly (trust me on this one!). Most of the cheap motors I've found are 208-230v and I just don't see the point in having a small 220v PORTABLE evap cooler, that's just dumb.
After a LOT of online research I've found the following motors that would be a suitable replacement, with all the above mentioned specifications. I'm sure there are more, but cross referencing this information for someone not in the business is tricky and time consuming.
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
I suppose that if you found a smoking deal on eBay for an "Open" type motor you could try it, but I doubt it would last long and make damn sure that ****** is grounded well.
Jul 06, 2010 | AdobeAir Mobile Swamp Evaporative Air...
Hamilton Beach Water Cooler with Storage Cabinet Logo
105 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
john h
Tom Chichester
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
