Canon PowerShot S1 IS Digital Camera Logo
Posted on Apr 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I put brand new batteries, it says "Change Batteries"
I have a Canon Power Shot S1 IS 3.2 mp 10X Digital Camera.
When I put brand new batteries in it and then turn it on, the display
picture (bird) comes on briefly, and then the screen goes black
and then the screen say "Change Baterries".
Can you tell me what the problem is?
Thanks
Anonymous
Level 2:
Sergeant:
  • Expert 246 Answers
  • Posted on Apr 10, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
246
Questions
0
Helped
102876
Points
760
Use a Q-tip with alcohol to clean all the batter contacts (battery cover and inside the battery compartment), and a small hook into the compartment to pull up the contacts a little bit up. The idea is to make the batteries connect properly.
Use NiMh rechargeable batteries or Alkaline batteries, don’t use other Dry batteries, which are not designed for digital camera.
3helpful
Whenever I put new batteries into my Canon Powershot A480, I get the same thing - I get the 'Low Battery' red flashing light. And Then as I go to take a picture it shuts off and says ; Change The Batties....
I've got the same problem with 2 A 480 canon. I put in NiMH batteries and they work fine. If you put in slightly drained used batteries they work!! Nimh batteries are 1.2 volts and Alkaline are 1.5 volts. There is definitly a problem with this camera. I measured the voltages of brand new batteries 1.51 volts each and they didn't work. I put in some old batteries 1.4 and 1.42 volts and they worked fine.
Canon Power shot A530 repeatedly displays "change
First make sure that you are using quality batteries, and not "super heavy duty". If so, some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please see this link for more info.
15helpful
2answers
I have a Canon Power Shot A520 and have just put in a new memory card 4GB and new batteries. When I turn on camera is says memory card error at the top of the sceen. Why is that?
The A520 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible.
You need to use SD cards 2GB and smaller.
1helpful
Power won't come on
You need to take your brand new camera back. You are not supposed to fix a new camera...you're supposed to enjoy it!
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Battires keep dying after first shot
Digital cameras require vast amounts of battery power. First check to see if the camera settings are on the simplest or default settings. If you are using batteries from some of the big warehouse stores check the expiration dates. The next thing you can try are the batteries labeled specifically for digital camera use. They have stronger holding power for the abuse the digital cameras can put on a battery. they are more expensive, so watch your overall cost. Another way you could go is to use rechargeable batteries and keep rotating fresh, charged batteries in thed camera.
My Canon power shot S2 IS does not detect the batteries
There is a battery charge level sensor in the DC/DC internal converter board.
It seems that just started to fail such board.
You can try with other brand or type of AA batteries.
If still you have the same problem, you will need to have replaced the DC/DC converter board on your camera. This means a Camera repair shop service on it.
Best regards,
Canon A400
Having using standard LR6 batteries in a Canon before you will only get 3 or 4 pics max before it drains the batteries. You really need high power AA's like 2300mAH+ rechargeables for any good performance or Lithium AA's
3answers
Power on n off
sounds like a battery power problem or problem with the terminal of the camera ; you know the point where the battery meets the camera.
I would recommend a service center
Canon S2IS
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S2".
Best regards,
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
