Question about Smith Corona Wordsmith 200 Typewriter
Caps lock I have an ka13 word smith. when i turn the poweron i cant get the caps unlocked. and what is the code key for
Posted by drjbox on
  • Anonymous Apr 16, 2009
    XE1950 keyboard locked. How do I unlock it
Anonymous
There isn't a "code" key, you just press the Shift key.  Unless you have a faulty machine, this is what removes the Caps Lock.
Posted on Apr 29, 2009
2000 Trooper LS. Why won't the ignition key unlock any of the doors? (the metal key part)
  • Some of the locks have been probably changed before.
  • Or you need to get original keys for truck, copies just get worn out by use.
Here a link to your SUV manufacturer:
Good Luck!
JP
Help Isuzu com
Jul 13, 2015 | Isuzu Cars & Trucks
1992 toyota 4runner ignition is locked cannot turn the key
I had the same problem and after reading this thread contacted an automobile lock smith. He stated that the first thing to do is get a new key made to the factory key code. The metal in the key is softer than the metal pins in the lock tumbler, and when you make copies from an old key it copies the wear plus some.
I did not have the key code fob that came with the car so the lock smith told me to take the VIN# to the Toyota dealer and they can cut a key based upon the stored code for my 4Runner.
$10 later it works fine with the new key and a heck of a lot cheaper than spending the $200 to have the ignigition drilled and replaced.
Apr 30, 2012 | 1996 Toyota 4Runner
While typing on my Smith Corona KA13, suddenly different letters and characters would type instead of the ones I was typing. Like an "H" instead of an "R". An "S" instead of a...
While typing on my Smith Corona KA13, suddenly different letters and characters would type instead of the ones I was typing. Like an "H" instead of an "R". An "S" instead of a "D"..... Any help please..
Jan 27, 2011 | Smith Corona Wordsmith 100 Typewriter
Key no longer works in ignition. I stopped to gas up and the key I normally use would not open the gas cap door. I re-entered the car and the key would not turn the ignition. The key unlocks the steering...
take it to a lock smith to remove the broken part or you could jam the broken part down to where the ignition will turn with the broken key. I advise taking it to a lock smith to remove the broken part
Feb 02, 2010 | 2001 Toyota Tundra
Key broke off in the key ignition switch and i cant get it out any ideas?
call a lock smith
if ignition turns turn it insert a pin or similar object into hole in botom of ignition and remove it
once removed take to lock smith have key removed and re cut
if it doesnt turn call lock smith and have them remove it and repair it lock smith will charge 100- 150 with mobile
dealer wont do mobile so tow 50 bucks then dealer charges 175 - 250 to remove and replace ignition
Jan 22, 2010 | 1990 Nissan 300ZX
Will not Type letter or numbers only types small things in upper corner of keys (blue), tried to reset but still no luck -Smith corona Model KA13
Their is a mode or function key on the keyboard somewhere. Use it to activate or deactivate the keyboard features.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Dec 17, 2009 | Smith Corona Wordsmith 200 Typewriter
Smith corona wordsmith typewriter model # ka13
The print head might have accummulated a lot of paper bits you need to clear them with a needle or just submerge the tip in petrol or ether. Caution do not submerge if its made of plastic.
Jun 21, 2009 | Smith Corona Wordsmith 100 Typewriter
Smith Corona Wordsmith 200 Typewriter Logo
199 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Ekse
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
