try this: The only known way to get VFO mode to work again is to connect the radio to a PC with a kenwood-compatible programming lead and use the puxing 6in1 software to turn off the lock option.
Check your settings for the RX frequency. Then check to see if the RX Tone is turn on and is set to the correct frequency. Just turning the rx tone off should allow you to hear any station coming in.
F121 VHF, F221 UHF they both use the latest Version 1.7. For F121 Factory default as follows:Open your CS-F100 software, enter RX TX frequency below, and write to the radio.Ch1: 136.100 MHzCh2: 155.100 MHzCh3: 173.900 MHz For F221 Enter RX TX frequency belowCh1: 440.000MHzCh2: 460.000MHzCh3: 489.000MHz, then write to your radio Or you check from this site:http://www.two-way-radio-tools.com/icom.html HP
Radio off, use moni & menu toghether, start radio keeping the 2 pushed for some time until SELF apears on display. Then insert magic code 5858. There are now 2 values on screen like 136 174 first is lower limit, second is higher limit, after moding ude Enter and restart radio. Remember that at extreme ends pll may not lock on tx or rx or both, this is phisycal limitation of the radio board.
