Kenmore 62602 Electric Dryer Logo
Question about Kenmore 62602 Electric Dryer
Loud buzz when starting, then shutting down after 10 min.
This is a Knemore series 80 dryer... the dryer has a loud buzz when starting - if i hold the start button the motor will engage and the buzz stops. the dryer will run for about 5 min, then start making a loud humming noise like a bathroom vent and then shut down 5 min later, if I let it rest for a few min, i can start the whole process again. is this the motor going bad? a new motor will run over $100. wanted to make sure it was the motor and nothing else before spending the money.
Posted by thephilguy on
  • thephilguy Apr 10, 2009
    thanks for the help - dryer is 11 years old, will need to decide to either replace the motor or buy a new energy efficient one.
Donni Steen
  • 687 Answers
Yes, this sounds like the motor cutting out on thermal lockout.
Posted on Apr 10, 2009
1helpful
2answers
Any idea why my dryer is shutting off after a short time?
Sounds like the motor is going into thermal overload and shutting down. If you here a Buzzing noise when you start dryer motors bad. If after you start the dryer wait and stop it after 10 min and then try and restart it if it buzzes and rattles bad motor.
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
My Kenmore 80 series dryer won't stay on unless I
Aha!
You are going to make me guess!
I am guessing you have to hold the start button down.
So.
Try a new start button first.
If that does not fix it, replace the timer/control unit.
God bless your efforts.
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
1helpful
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Mar 13, 2011 • Dryers
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
1helpful
Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 • Dryers
1helpful
2answers
Top Kenmore Dryers Experts
Marvin
Marvin
Mike
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
