Washing Machines Logo
A
Anonymous Posted on Aug 25, 2013
Removing pedestal drawer from whirlpool LAB2700LQ0
4 Related Answers
Anonymous
  • 848 Answers
  • Posted on Oct 30, 2008
SOURCE: remove washer pedestal drawer
  • Open the drawer fully. Look at the rear of the support slide is there a small, black plastic lever on one side push the lever down, the other side pull the lever up.
  • Remove the small screw on either side of the support slide at the front of the drawer. Lift the drawer and push support slide away from the drawer
Anonymous
  • Posted on Feb 14, 2009
SOURCE: need to remove drawer from
I just removed the drawers, you need to remove one each 1/4" head sheet metal screw from the end closest tot he drawer front. this will allow you to slide the drawers out and clean the mess undere both the dryer and the washer. repeat steps to reinstall. Takes about 2 min to remove both doors, Hint: a 1/4 socket works better than a wrench.
Anonymous
  • 82 Answers
  • Posted on Jun 29, 2009
SOURCE: How can I remove the Whirlpool Duet washer pedestal drawer?
there should be a clip on the top or bottom if not pull it out as far as it will go grab it on both sides and pull sharpley towards you DO NOT GRAB THE FRONT IT WILL BREAK
Anonymous
  • 262 Answers
  • Posted on Jan 11, 2010
SOURCE: how do you get the bottom pedestal drawer out,of a
The drawer has release clips on the rails. They are a pain somtimes. One one each rail.
How do I remove a pedestal drawer on and electrolux dryer
Hello friend, thanks for your inquiry!
I have researched that information for you and was unable to locate steps on how to remove the drawer from your pedestal. I would suggest seeking assistance from a professional for proper removal of the drawer. Hopefully this helps. -Matt
Remove washer pedestal drawer Cannot remove drawer to check behind or underneath, please help.
1helpful
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
17helpful
How to remove drawer on pedestal
You need to remove the 2 screws holding the black rails on both sides of the drawer. Took us a while to figure this one out also.
How do you remove the washer from the pedestal?
not an easy task---try to remove the drawer. there is a bolt going upwards in each corner (inside)
11helpful
2answers
When you look this will not appear to be how it is done but it is in fact the way. Pull the drawer all the way out and then look on the side of the drawer at the very front and you will see a single small screw that attaches the track to the drawer. It would appear this is part of a series of screws and the track itself should seperate but neither side of the track removes. Simply remove these screws on both sides of the drawer with a small hex head socket and the drawer will pull right out. Push the tracks back into the pedestal until done cleaning the drawer.
Need new drawer leveling feet
goto Sears.com .. look under parts.. key model # if you have it..
10helpful
2answers
Washer is off balance. Need to get to levelers.
I had the same problem...thanks for posting a solution. I agree with the solution posted above, but on my unit they are 1/4" HEX head screws, not phillips. Look at the illustration on page 4 here for help:
http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/XHP1550VB_Installation%20Instruction.pdf
I hope that helps.....
Remove pedestal drawer from washer
First remove the top of the washer via 3 tork, 7mm hex head screws (they are hidden located on rear of washer) then you can see to line up the tub with the shipping bolts. Just put 2 in --one lower and upper opposing each other and that will be sufficient. I believe there is two screws holding the drawer in located at the track towards the front of the drawer. Now you can lean it over with no worries to remove pedestal
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
