SOURCE: voice mail icon stuck on
I had this problem on my pocket pc phone. FINALLY found the answer here: http://thedailyinvention.com/?p=565 hope that helps
SOURCE: Voice Mail - Hotkey #1
hi there penny yes i was about to say dial 121 thatll take you straight to your message inbox voicemail box or ring your servic provider and get them to go through step by step with your voicemail settings hope this helps and if you have time please rate me
thanks again
SOURCE: how di i set up voice mail
dial your own number on your phone, and when it starts the automated voice inbox, press the pound key.
SOURCE: The voice mail icon (the little audio tape
under your menus look for alerts. you should be able to find something refering to your voicemail alert to clear it.
SOURCE: can't get the keyboard back when on a call or voicemail
It says press the "hold key" to bring up the key pad, which is on the right side of the phone, next to the camera button.
enter voicemail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voicemail message, you must press 3, delete the original message and reset the message followed by the #.
have uploaded a video off http://www.abbeytelecom.com which explains Voice-mail in more detail, if you are operating a differant system then I can only suggest that you rafer to the relevant operators manual
http://www.abbeytelecom.com for written copy
