Xerox DocuColor 12 Printer Logo
Posted on Apr 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Machine in ready to print condition but the fiery did not support, fiery shows load heavyweight in tray 5, and the command workstation did not work properly, no ripping, no spooling the cross cable is ok, I think the fiery can't connect to the printer.
ARUN BORA
Level 2:
Champion:
  • Expert 241 Answers
  • Posted on Mar 29, 2010
ARUN BORA
Expert
Level 2:
Champion:
Answers
241
Questions
5
Helped
87274
Points
457
Issue with ur paper size or tray 5 paper sensor
I am getting a 'disk full' message on the Fiery. How do I delete it?
TROUBLESHOOTING
This chapter provides troubleshooting tips.
Troubleshooting the Fiery
Startup diagnostics are described in the documentation for service technicians. Contact your
authorized service/support center if you see error messages while Command WorkStation is
starting or if the Fiery does not reach the Idle state.
Runtime error messages
For error messages related to canceling jobs and printing, including the Disk Full message and
alerts to load media, see Command WorkStation Help.
For error messages related to the copier, see the documentation that accompanies your copier.
You can turn on PostScript error reporting as a print option from Mac OS applications.
Printer not found
Most failures to find a printer on the network are due to conflicting or missing name or
address settings for the Fiery. You must type names in specific places. The required names are:
•TCP/IP host name (also known as the DNS name), which is defined by your organization.
Type the host name as the Server Name in Fiery Setup.
•Remote printer (internal machine) name. Use one of the following:
print
hold
direct
NOTE: If you change the DNS name (also known as the TCP/IP host name) of the Fiery, you
must reconfigure one of the utilities on each workstation. http://swdownload.efi.com/ftpvefigs/9019710383/2822679259/9432346727/7795362481/Configuration.pdf
Xeroc docu color 250
If you are printing from an Adobe product make sure you are printing as image and let the printer manage the colors. Also, try calibrating and updating the machine through Command Workstation which can be downloaded for free from www.Efi.com. Download the updates by going to the Fiery web interface by typing the ip address of the copier in the web browser and going to the configure tab and clicking on check for updates. Make sure you install them in order and reboot the machine in-between updates. ALSO, you can import the file directly into the fiery by using command workstation avoiding any driver complications.
1helpful
Fiery unit s400 will not work
If you press the Fiery button on the copier does the copier display the Fiery logo and the menu. If yes you are just missing the Fiery software for the workstation (called Command Workstation I believe). If no you will need a service call to possibly reload system software.
DC12 Fiery EX12 network problem with vista
Remember some times Windows Vista disable the spool service, only you have to enanble it and ready..
3answers
Fiery xp12 is loading without end
Have you checked the paper trays are filled and ready? Also unplug for a couple of min's and see if that clears the memory as it may be trying to forfill a print request the never compleated.... Had this happen a few times....
Hope this helps.....
5helpful
2answers
Command Workstation for fiery x15
xerox.com look for dc 3535 in support and drivers and the new command workstation is in there
First 30 pages of a print run after 24hrs idle are blank
don't upgrade the xp, it runs a limited version to ensure that the command workstation works ok. A reload is probably in order to start again. Any updates can generally be found on the xerox website, and installed via command workstation
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
