Error code 3502
error code 3820
error code 3515
I can not get my printer to finish printing a test page.
Any ideas?
Error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
for more hrlp visit CBR Tech Solutions
SOURCE: Printing 1/2 page
Ok, this is what I found when I finally broke down and decided to take it apart. There is a bar with two cams on either side of it that are used to engage the print head to the paper. The smaller cam on the bar has cracked and no longer pushes the print head down on that side of the paper, causing the half picture. What I did was remove the cam from the bar, glue it back together, then wrapped it tight with thread (only one layer, there is a clearance issue), and put epoxy around the thread(to help reinforce the cam). Once the epoxy had cured, I reinstalled the cam to the bar. The cam did crack again, but the thread and epoxy held it tight to the bar. After reinstalling the bar and putting the rest of the printer back together, I crossed my fingers and tried to print a picture. Tada!! It worked!! I have since printed a few more and have not had a problem yet. It may only be a temporary fix, and nothing could be better then the original replacement part (if you know where to get it), but this has worked for me. Good luck and be patient.
SOURCE: Kodak EasyShare 5300 Printer error message
Ten Step Process to Fix the "Print Head" Error Message on the Kodak 5300 Printer.
1. Clear a good spot it your back yard that is free of shrups and flowers.
2. Get the following tools: Flat head screwdriver, shovel, sledgehammer.
3. Dig 24" x 24" hole in your back yard and rope off the excavation area for safety.
4. Whaaaaack the heck out of the Kodak 5300 with the sledgehammmer until such time that it is not a recognizeable piece of electronic equipment.
5. Stab it with the flat head screwdriver, just in case it has the Terminator syndrome (comes back to life).
6. Throw the piece of garbage in the recently excavated hole in your back yard.
7. Cover up that useless piece of garbage and forget you ever owned it.
8. Get in your car and go to the nearest electronic store and ask to speak to the manager.
9. Ask if they sell the Kodak 5300 printer. If so, whack him with the shovel. You don't want to seriously injure him so don't even consider the sledgehammer of the screwdriver. After all, its not his fault that his company carries such garbarge. But the whack is just to burn off some steam from your frustrations.
10. Purchase any other printer but a Kodak and live happily ever after.
SOURCE: Kodak EASYSHARE 5500 will not print with black ink
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
SOURCE: Printer Kodak Easyshare 5300 Will not print black ink
Close the printer.
