Question about Canon imageCLASS MF8170C All-In-One Laser Printer
I wanted one paper printed instead of one i have a whole pile of papers how do i stop same documents printing
Posted by amjadraja3 on
  • Anonymous May 11, 2010
    have you checked that your defalut setting to print only one copy?
Geoff
  • 562 Answers
Open "File"
Open "Print"
Goto "Print range"
Click on "Pages"
In the first box enter the number of the page you want to print
In the second box enter the number of copies you want.
If you want only 1 copy enter 1 in both of the boxes..
Hope this helps
Posted on Apr 10, 2009
Why can't I print to my Ricoh Aficio SP C430DN from my Macbook Air?
You probably have a conflict between the paper size the machine knows is loaded and the document size being specified for printing on. Your Airbook is probably trying to send a document on a paper size the printer doesn't have. Net result is a document stored in the print queue that stops anything else being printed. Go full system reboot and clear out any and all waiting documents before trying again.
Sep 08, 2014 | Ricoh Aficio SP C430dn Laser Printer
Inconsistent printing
In the printer's dialogue find the print pages number. Print page from/to and select 20 pages chunks. In effect print only part of the document at a time. Add all chunks together in one pile. Work around I know, but it works.
Aug 02, 2017 | Brother HL-2130 monochrome laser printer...
Hp 2280 wont print says no paper or ink
Start by uninstalling the printer software... then re-install the newest software from the HP website. Always works for me...
Jan 25, 2012 | HP DeskJet F380 All-In-One Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
How do you set it to print in LTR instead of
Inside the paper cassete there is a dial were you can set your papersize.It is a blue manual switch switch it to LTR instead of LTR -R.There is also a document stop that you can remove to set it to the correct paper size.If you print from your document select portrait insted of lanscape.
Thanks for your support.
Dec 28, 2009 | Canon imageRUNNER 2270 Copier
The printer does not print. It feeds paper and
Visit HP support for this problem (XP):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01853840&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443024
If you have Vista, change query to read "Printer prints blank sheets of paper" > Choose Vista instead of XP
Dec 05, 2009 | HP Photosmart 8250 InkJet Printer
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Error after pulling out paper drawer during printing
The error button is probably flashing because there is paper in the printer that did not feed through. or just power off the printer and power back on and see if that helps
Dec 18, 2008 | Brother HL 5250DN Laser Printer
Paper Feed
The problems are particularly frustrating if it's a Word 2007 document that you're trying to print. Open the document, go to the Page Layout tab, select Page Set Up > Paper and set your printer source to whichever tray you want. Apply to the whole document and voila !
Apr 08, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
Canon imageCLASS MF8170C All-In-One Laser Printer Logo
82 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
