SOURCE: how to program frequences in a radius p110 radio
The P110 radio is computer programmable. The software is Motorola proprietary, so it is only available to Motorola dealers and a few select types of end-users. The best option is to have it programmed by a dealer. (Just for a cost example: Our dealership does them for $15 plus shipping.)
SOURCE: Motorola CP200, radio just beeps when im pressing any button.
It is possible your radio is not programmed, or has a bad/old battery.
It is normal for the side buttons 1 and 2 to beep when depressed to indicate you turned the feature on/off. Each of these buttons has the ability to be programmed a long and a short press feature.
If your radio beeps when your press the PTT button, on any or all channels, it indicates a low or nearly dead battery. Check your battery date code to see if the battery needs replaced.
If your radio emits a long tone on a channel, that channel is not programmed to function.
If your radio beeps a single beep when you turn it on, this is normal.
Charge your radio completely overnight, with the radio turned off. See if this solves the problem. If not, try a new/different battery to see if it will solve the issue. If not, drop by your local dealer and let them look at the unit.
SOURCE: need to program in 1-10 frequency...is this possible ?
Okay, I'm going to attempt to assist you with this. If your TalkAbout 200 has a screen showing your channel number and a smaller number in the upper right. It is possible your radio could be programmed to match another TalkAbout or FRS (family radio service) style radio. I cannot find an owners manual in English for the T200. Here is one you can translate from Czech http://www.cbradio.cz/doc/Motorola/PMR%20TA200/manual.pdf (Simply copy and paste this into a google search with the word translate in front of it.) It will give you the instructions for reprogramming your "interference eliminator code", aka CTCSS. Your radio has 14 built in frequencies. From your explanation I would assume you need your BIG number to be 1, and your small number to be 10.
If your TalkAbout does not have a screen, you will not be able to do the CTCSS #10. It is a CSQ model only.
Sidenote: If the other radios you are wanting to talk to are NOT FRS-type or TalkAbout radios, your radio will not match them.
SOURCE: Motorola SP50 Programming
The SP50 is dealer programmable. The software, cable and RIB (radio interface box) are necessary for programming this unit. If you are needing to match an existing unit, you can have the radio programmed at your local dealer or by shipping your radios to a service center. (Typically $15 to $25 US)
When looking for the second radio, be certain to get an SP50 with the same model number as your existing unit to ensure they will work together properly. Model numbers beginning with P93 are VHF and P94 are UHF.
SOURCE: Hi, i bought a Motorola CP200 radio and realised
Take it too radio-shack and ask the salesman to try out a frequency meter to get the freq. you can get programming help by contacting motorola direct...1-800-638-5119
Testimonial: "great and fast acurate info!!! "
