Black & Decker PS130 12V  Battery  Logo
Anonymous Posted on Aug 24, 2013
How long should it take to charge a PS130 battery? I have had it on a charger two days and the charger light still red...
HH Gladish
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Feb 20, 2022
HH Gladish
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
Questions
Helped
671
Points
6
The light will stay RED as long as you have a battery in the charger - it does not go out once the battery is charged - so DO NOT leave your battery in the charger for longer than the recommended time
Woody J Hiatt
Level 2:
Sergeant:
  • Expert 306 Answers
  • Posted on Sep 07, 2013
Woody J Hiatt
Expert
Level 2:
Sergeant:
Answers
306
Questions
Helped
108325
Points
773
Not that long! You got a problem.
1helpful
How can i charge my b&d 12volt ps130 batteries without a charger
A Dewalt 12 V or I use the universal charger works on my B & D Firestorm trimmers battery How technical are you I could Explain to you how to set up a 12V ( > 13VDC) power supply to the terminals on the battery but you have to be Extra careful not to over charge ! You can pick up Firestorm chargers for about $ 15.00 on Ebay
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
The red light is always on, and it doesn't seem to be charging. Its almost brand new.
Same thing started happening to me. The red charging light was initially going out but then after a few days use started staying on. I assumed that the battery was damaged and bought 3 new batteries but the red light is still staying on when I charge the new batteries.
I suspect that the mains charger I was using (same voltage but not the recommended charger) has perhaps damaged a component inside the EFLC1003 unit which is now not letting the power through to charge the battery.
1helpful
The charger for my Black and Decker PS130 power pack batteries just quit on me. Apparently, other folks have had the same problem so I don't want to replace it. I subsequently bought a Dewalt DW9118 but...
For the price a Dewalt costs, you can buy a few reconditioned cheap cordless drills and keep them all charged up. You will always have a standby. You can also check the pawn shops. With times like they are many people are getting rid of good stuff. You can find a great deat but always use a trustworthy pawn shop and get a receipt with the serial number on it. Theives like pawn shops, too.
Happy Hunting!
3helpful
My new 18v lithium batteries run out of charge after about 10 mins of continuous use is this about roght as my old Nicad batteries would go for about 20 mins this is using them with a drill driver with a...
This is not right. They should last much longer then that. I have one of the more expensive 18V lithium batteries (the one with the button on it that tells you if it needs charging or not) and I can use mine almost all day before it needs to be recharged. I do construction work and I use my Ryobi products almost all day. Either both batteries are bad (I don't believe that is the case) or the charger is not charging them all the way to a full charge. With this charger, you do need to make sure that you remove the batteries as soon as the green light comes on. It is not good on these batteries to stay charging after they are fully charged. You also should not leave the charger plugged in without any batteries charging.Please tell me more about the charger. When you plug in the charger, does the red light come on? When you plug in a battery, does the red light stay bright and the green light blink? Does the red light go off and the green light stay on bright when you remove it from the charger?
If the charger is not working correctly, then return it for a new one.
4helpful
How long should I let my battery recharge?
If you have the PS130 12v Battery, and the one-hour rapid charger from Black and Decker, then, in theory, it should only take an hour to charge the battery (according to them). However, I would leave the battery on charge for at least several hours to guarantee a full charge each time. That battery is a NiCad cell battery, and these typically take longer to reach a full capacity charge. So give it a few hours at least, but it probably wont hurt it if you left the battery on charge even overnight either... But don't let them charge for longer than 18 hours maximum!
42helpful
10answers
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 • Cameras
Battery won't charge.
hello,
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
TY
Top Black & Decker Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Black & Decker Measuring Tool and Sensor Expert? Answer questions, earn points and help others
