Question about RIM BlackBerry Pearl Flip 8220 Cellular Phone
Reload software 513 error
Password entered wrong, phone wiped, receiving error message reload software 513, how do I handle
Posted by vankilma on
  • vankilma Apr 10, 2009
    i understand that it means reload software, OS, but don't have the software
Avinash Raj
  • 541 Answers
After typing an incorrect password ten times and restarting the BlackBerry smartphone, the following error appears:JVM 513
All of the data and applications on the BlackBerry smartphone have been deleted and The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone (Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader)
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps:
1) Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2) Double-click Application Loader.
3) Click Add/Remove Applications.
4) Type your BlackBerry smartphone password and click OK.
5) Select the check boxes next to the names of the applications you want to load.
6) Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
7) Click OK.
8) Click Next > Finish
9) When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
Posted on Aug 10, 2009
My blackberry phone kept asking for the password and after that it just went blank and said it was gonna wipe out all the info on my phone. Now I can not turn my phone on cause it keeps saying reload...
If the password was entered incorrectly a few types the Blackberry will say that it will wipe the entire contents back to factory. The error is unusual though. What you need to do is plug the phone into your computer and within the Blackberry software perform a full restore of the firmware software. This should fix the issue and put the phone in working order.
May 04, 2011 | RIM BlackBerry Bold 9000 Smartphone
My blackberry storm 9500...I put in my password and that didnt work, did it ten times, then asked me to enter blackberry..it started to wipe it self..and now it displays Reload software: 513
It will if you get your password wrong. That is part of the security process.
Re load software from your desktop programme and restore your backup.
Jan 09, 2011 | Computers & Internet
WHITE SCREEN RELOAD 513
Reload 513 appears when you have entered wrong password from some specified number of time.Due to this the phone wipes of the data fully.Now you need to reinstall the software.
Go to below website and this will show how to update the software
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB11320
Thank You
Nov 29, 2010 | Cell Phones
Reload software 513 on blackberry bold 9700
you need to call att and they can get you to data support and they can fix it.
Feb 28, 2010 | RIM BlackBerry Bold 9700 Smartphone
Blackberry Bold 9700 - RELOAD SOFTWARE 513
all you need to do is sync your blackberry with your blackberry desktop manager and run the application loader. you will lose all data on the phone because you will be re-installing the software
I have put in the wrong pass word and now have a JVM error 513 how do I get this off my phone and reactivate the phone
just enter it till the sftware says everything will be wiped offf if yu enter the wrong password again,,well enter it..it will delete eveeything frm the phone and then reinstall useing blackberry offive manager software..its easy
Feb 05, 2010 | RIM BlackBerry Pearl 8100
Need to reload software 513 blackberry
the Application error 513, reset message says that the device OS is toasted and needs to be rebuilt. In order to do this, you need to have Blackberry Desktop manager on your computer, your data cable, and a download for your device software. Either from blackberry or your carrier. The easiest method is to download and install the device software. Once it's installed, launch desktop manager and plug in the phone. If the phone is detected, you will be prompted to update. Follow the prompts. If not, you will have to do it the hard way. open command prompt (start>run>cmd) and goto C:\program files\common files\Research in Motion\Apploader Then choose Loader /NOJVM That's going to rebuild the blackberry.
Mar 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Bb 8310
the password i kept typin in was wrong on my blackberry curve, so it started wiping everything and now it says JUM error 513 and it wont get into my phone,the only way it turns off is by taking the battery off,i tried reseting it and it goes to the same screen? what can i do to get in my phone?
Aug 11, 2008 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
4,418 people viewed this question
Top RIM Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Vincent G
Vincent G
Marvin
Marvin
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
