Question about Sharp AQUOS LC-60LE832U 60" Class LED LCD HDTV
We have a Sharp Aquos 60 inch 3D Smart TV and after a lightening storm, the TV, Blu Ray and Satelite box stopped working. Just wondering if the fix to the TV might be as simple as a blown fuse? and if so where would I find it to change it?
Posted by Sherrie Pelusi on
stephenstheodore
    New Friend:
I dont think so.It is likely been killed by the lightning.Sorry
Posted on Aug 24, 2013
3 Related Answers
Anonymous
  • 3422 Answers
SOURCE: Sharp Aquos LC42d64u has blurry picture...
Is it slow and blurry? if yes then return it to warranty immediately. The video processing circuits are malfunctioning and the repair cost is prohibitive if you must pay for it on your own.
I hope it is still under warranty. So, do not delay getting it into the Sharp Authorized facility or back to the retailer you purchased it from.
The connection cable you use could have something to do with it, but is should work on all formats. The best for reliability and absence of blocking is just analog composite - but that is also the lowest picture resolution. S-video is okey too, but it is analog as well. Component is the highest grade; going to hdmi is just another way of receiving the signal - I don't think it will effect the error correction problem in any way. My opinion.
Goodluck..
Posted on Feb 25, 2008
Anonymous
SOURCE: Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Posted on Apr 25, 2011
bugoy31
bonifacio gomez
  • 1238 Answers
SOURCE: 60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Posted on Dec 19, 2011
Is the sharp aquos 40 inch lc40c45u tv compatible with blu ray
Any set with the matching inputs should work with blue ray.
RE: Aquos LC40C32U. I replaced the power supply bd a year ago, cost $110. It has failed again (no power light.) ater a series of lightening storms. I am reluctant to spend more money on it. What is...
You can't blame any component in the TV failing after lightening storms. Get lightening arrestors on the antenna cable and use a surge protector on the power cord before you replace the power board again.
Hi...I also have a Sharp BD-HP24U. My problem is When I load the new expendables disc, it only seems to load the scull and wings logo of the movie about 3/4 of the way across from left to right then stops....
I had this exact same problem with the Expendables. I have a Sharp BD-HP22U. I found this fix on another site regarding another movie. I thought it was a long shot, but gave it a try anyway....and it worked. Here's what to do: Turn off whichever device (TV or Receiver) your HDMI cable is going into - turn on Blu-Ray player, load Blu-Ray disc and then turn on the other device. Hope this works for you.
Hope this helps folks. :)
4helpful
1helpful
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Sharp AQUOS LC-60LE832U 60" Class LED LCD HDTV Logo
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
