Computers & Internet Logo
Posted on Apr 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer doesn't power up. There is power throught the motherboard as my speakers have power. There was power to my mouse but that seems to have gone now. Has been working fine to date but went to turn it on this morning and nothing happened. There have been no power outages or fluctuations. The computer was working last night. Recently been in for installation of graphics card.
Anonymous
Level 2:
  • Expert 59 Answers
  • Posted on Apr 10, 2009
Anonymous
Expert
Level 2:
Answers
59
Questions
Helped
17247
Points
209
DEAR FRIEND
PLEASE PERFORM FOLLOWING STEPS
1. check whether your cpu fan powers up or not, if yes then check ram , if not proceed to step 2.
2. change smps. see if it works, if not goto step 3
3. change the mb, 100% your mb has gone dead, the symptoms you are telling match both the smps failure as well as m/b failure
thanks
Anonymous
Level 3:
  • Master 432 Answers
Anonymous
Master
Level 3:
Answers
432
Questions
0
Helped
197657
Points
1334
Might be that the power supply you have does not have enough wattage or power to power the new graphics card you have. If you insert or install your old graphics card does that allow it to work ?
Also what wattage power supply do you have and what new graphics card did you get, does the new graphics card have a molex on it to allow you to connect an actual power connector to it ( presuming it will be a 5 volts molex connector ) ?
Some graphics cards require extra power hence the molex conncetors.
I have a HP Pavilion Slimline s3700y that doesn't always boot. Power is getting to the computer; the light on the back lights up as well as the lights on the front. However, power doesn't seem to...
If you saying "doesn't always boot", most common would be motherboard...
If your motherboard still beeps, then probably some other components has the problem like RAM, GPU card etc., depends on your motherboard.
Hope that give an idea...
How to build a or assemble a computer and troubleshoot?
Building a computer will require: a motherboard, a processor, memory, a video card or motherboard with onboard video, a sound card or motherboard with onboard sound, at least one hard drive, a CD or DVD drive, a case for the computer components, a power supply, fans to cool the computer, an operating system, a monitor, speakers, keyboard, mouse, 2-3 hours to assemble the computer.
You must ensure that all of the components are compatible with one another. After receiving the parts, lay everything out on a large, clean surface. Make sure you are grounded by touching a metal surface; this will prevent the transfer of static electricity to your computer components.
Typically, the steps to install the components are as follows: 1. mount the power supply in the case, 2. mount the motherboard 3. lock the processor in the socket on the motherboard 4. insert the memory sticks into the slots on the motherboard 5. mount the processor fan on the processor 6. insert the video card into the applicable slot on the motherboard 7. insert the hard drive into a hard drive bay in the case, 8. insert the CD drive into a CD drive bay, 9. mount any fans you have to the fan cutouts on the case 10. connect all applicable data cables to the CD and hard drives 11. connect all applicable power cables to the motherboard, video card, processor, hard drive, CD drive, and any other components. 12. connect the front panel USB, power, lights, and reset connectors to the motherboard 13. close the case 14. connect the power, monitor, speakers, keyboard, and mouse to the computer
Because this process is rather involved, I recommend following a guide such as this one: http://www.maximumpc.com/article/how-tos/how-_build_silent_gaming_pc
It details the process, includes pictures, and even provides a list of compatible parts.
My computer doesn't start power supply checked - ok connection checked - ok
Hi There,
Firstly, disconnect everthing from the Power supply EXCEPT the motherboard
1. Does the fan on the CPU spin when switching on?
Double check power switch connections to motherboard, sometimes if connected incorrectly, it may stop the board from powering up.
2. Attach the PC speaker to motherboard and remove RAM, REMEMBER to follow all antistatic rules when doing anything inside the computer.
Switch machine on and listen if it makes a sound. if it does then the motherboard is fine.
Have you recently fitted the board yourself?, if so make sure it is not earthing on to the casing.
Try these first and let me know how you go.
neil
My computer has no sound,What to do? I don't heard
Let's start with restart the computer. That usually gets everything glitchy to work again. If that doesn't help, hit me back and we'll dig deeper.
When power on my computer averatec, screen show lines and move the mouse this line, move with the mouse, i think the problems is the grafic card nvidia P419
You are prolly correct. Try making sure you video cable isnt loose first then update windows to make sure you have the correct driver.If it doesn't work then buy a cheap card.
My computer wont turn on at all??
- unplug everything form the back of the computer: power cable, mouse, keyboard, monitor, network cable & speakers, printer, camera (all usb)
- hold down power button for 10 secs (power cycle)
- plug in power, keyboard, mouse, network & monitor.. BUT NOT printer yet
- it it turns on, you can reconnect all other devices
- if it doesnt turn on still, call manufacturer or bring it to repair shop.. possible motherboard problem
4helpful
3answers
Lost the installation CD for my creative SBS 240 speakers
u can download them from www.creative.com or search in google for creative speakers. then click the first link and in that go to supprt and drivers , in that choose ur model.
Acer aspire laptop mouse and keyboard not working
  1. first check the bios.
  2. you can use serial mouse or keyboard change this parallel mouse and keyboard.
How to turn the Notebook Optical Mouse lights off?
On some motherboards you can turn off the USB power in standby mode in the BIOS settings. Some motherboards do not have this feature and you need to switch off the power at the socket.
Grand Canyon Tech
Grand Canyon Tech
