Question about JVC KD-SX770 CD Player
Dosent play burnt cds
Crackles when u play burnt cds
also plays originals perfect
Posted by mrdj2u on
Anonymous
  • 700 Answers
Try to burn cd in 4x speed burn. Or try to burn the audio as CDDA format at lower speed burn.
Crackes usually appears when burn the cd at high speed.
Pls. leave a comment
Posted on Apr 10, 2009
Comes up with e05 when inserting a cd
is it a burnt cd? that sterio wont play burnt cds only originals. nice 1992 jetta.
Mar 05, 2013 | Car Audio & Video
My head unit will not play burnt cds
I have a similar problem, When i try to play burnt cd's it would sometimes work and sometimes would skip or crackle as if it cannot read. I tried a standard bought cd and worked flawlessly so it cannot be the lens.
One thing i tried is when burning music to the disc turn the "write speed" right down to the slowest setting. If using Windows Media Player it is available by pressing Alt then navigating to the options menu. select burn -> write speed -> slowest. It doesnt go much slower but i think it writes less errors to the cd which makes it like a standard bought cd.
Hope this sheds some light on the situtation and good luck,
Gh0st
Jul 30, 2012 | Alpine Case Cda-7873 Cda-7875 Cda-7876...
JVC CA-D661T compact home stereo stopped playing burned CDs (it used to play these same CDs, now it doesn't recognize them). Everything else works, including playing of original CDs. Any ideas?
You can try cleaning the laser lens. You can do this using qtips and rubbing alcohol. Be sure you are very gentle though or you could risk scratching the lens which would completely ruin the laser assembly.
Mar 21, 2012 | Car Audio & Video
Drive dosent play anything no games cds dvds could it be a laser problem
drive dosent play anything no games cds dvds could it be a laser problem
Oct 14, 2009 | Microsoft Xbox 360 Console
Philips DVD Player model DVD622/37 wont play movies
Unplug/replug unit, try commercial dvd's again. If fails - call Philips- find out about replacement options
Jun 29, 2008 | Philips DVD 622 DVD Player
CD player won't play CDs burned on new computer
hi penguinxy.
try get a original cds if it works fine.the next time you burn cd try burn at 8x or low may be your cd lens is not detecting cds burnt at high speed.hope this helps..
May 10, 2008 | Jensen CD-2010X CD Player
Brnt cd's?
angel1986..some decks will not play burnt cds .it was the way they made them..
Feb 08, 2008 | Car Audio & Video
What do I do with an E2 error?
maby way your buring them what brand uusing
Feb 04, 2008 | Panasonic CQ-DP101U CD Player
Playing CD-RW audio CDs on Kenwood DP-J2070
try to play a song from original cds.
maybe you brunt it in mp3 file, or its a different format. try to burn your song to cd-r.
if still, try to use nero to burner..
if it wont play your original cds and burnt cds,then the optical lens or the board is broken.
hope I helped you.
Dec 06, 2007 | Kenwood DP-J2070 CD Player
Crackling from surrond sound
I have a SONY home theater4.gif system, HT-C800DP, there is a crackling sound when playing DVDs - it is almost as if the unit overheats. Is there any solution to this? Sometimes I cannot even finish a DVD as the noise gets very loud.
Thanks,
Cindy
Aug 14, 2006 | Sony HTD-C800DP System
JVC KD-SX770 CD Player Logo
196 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
