SOURCE: Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
SOURCE: fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
SOURCE: Multi colored lines running from top of screen to bottom
panel is cracked the cost of the repair is usually about 90 percent of the cost of the tv when purchased new. panel and labor. not worth if panel is cracked.
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
