Question about Integra DTR 5.6 Multi Media Amp
Integra DTR-5.6, all displays work, fuses good, but no sound
5 Related Answers
Anonymous
  • 9 Answers
SOURCE: Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
Peter Bradley
  • 57 Answers
SOURCE: my left rear speaker has no sound. All others
Swap your left and right rear speaker over. If you still get no sound from the right speaker connected to the left speaker connection on the receiver, then you have a fault on the receiver output. Check your manual first to see if any setting switch off the rear speaker before taking the unit for repair or replace
Posted on Nov 26, 2009
reyjoshua07
Reynaldo Labaguis Jr.
  • 1157 Answers
SOURCE: Integra DTR 7.8 - front
Hi Jzargo,
I would just like to ask if your system's display on the front of the unit wont light up? If the unit appears to be working fine but just no display, it might caused by defective resistor in the display. If your system is still in warranty, I recommend to have the service center replace the defective resistor in the display for free.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 20, 2011
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: my integra dtr 5.6 receiver
hi,
As you have mensioned it should be power supply problem. You have to check the voltage regulators at it power supply satge. it should need a good electronics servicing skill to find out the exact problem. if you are not experienced in it, then i will prefer you to consult some one more experience in it for such a costly system.
ok
Posted on Jul 30, 2011
jdvillanueva
Jdvillanueva
  • 2098 Answers
SOURCE: my integra dtr-40.2 reciever will
Please unplug the unit from the outlet for 15 mins and then check if the symptoms still there.
Reset the unit to factory setting by following the steps below.
> Power on the unit.
> Press VCR/DVR button key + On/standby key at the same time to re-initialized the memory to factory settings.
Check also if the remote control is working fine. Aim the sensor of the remote control directly to your cellphone camera, while pressing any button key from the remote control (button key with an issue) you will be able to see the flash of an infrared emitted by the remote control indicating that it is working fine. Watch the video below for more info.
Jdvillanueva
Posted on Sep 13, 2011
My integra av receiver model no DTR-70.1 amplifier displays but no sound what could be the problem?
http://www.integrahometheater.com/faqs.php Check the connections and try a master reset?
Perform a master reset. To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode.
Jul 03, 2018 | Integra Audio Players & Recorders
I am not getting any audio (sound) out of my Integra DTR 4.6. Any suggestions?
Does the vu meter show anything(bars moving up and down when audio is present?If so you may have a blown fuse or bad IC in the amplifier section causing the problem. If there is no indication of audio on the front panel it would be a Microprocessor problem
Oct 15, 2014 | RCA Onkyo Integra Dtr-4.6 Av Receiver Wrat
How to fix Integra 7.8 display is dead
They will be value of 10 ohms or less in the secondary power supply attached to the front assembly
Jul 20, 2014 | Integra Dtr-7.8 Receiver
"handshake" between DTR 5.9 and an LG Blu-ray player
You will have a defective processor pcb. You may want to see if you can get Integra to give you a one time repair on this.
Mar 26, 2014 | Integra Onkyo Rc-711m Dtr-4.9 / 5.9...
It wont turn on
Be sure the power relay has the proper voltage going to it. if so try a reset,if that don't work and all fuses are good you may have a defective micro.
Mar 19, 2014 | Integra Dtr-4.9 Av Receiver
Integra DTR-5.6, no sound for am/fm tuner
reset receiver if that does not work You will have a defective processor pcb
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
How do I set up an Integra DTR 7.8 for 3D display and audio
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
May 17, 2012 | Integra Audio Players & Recorders
I have a Integra receiver model number DTR 66 and I have no sound. it appears to have everything connected and should be working. I would like to know how to reset the receiver or what steps do I need to...
NO sound at all? That would be odd as its internal FM receiver is independent of any user connections. I'd work on getting FM to work first, then move on to more complex issues.
The manual is here:
http://www.retrevo.com/support/Integra-DTR-6.6-Receivers-manual/id/550ag000/t/2/
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [Video 1] button, press the [Standby/On] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Dec 26, 2010 | Audio Players & Recorders
Jun 30, 2009 | Integra DTR-5.2 Receiver
Integra DTR 5.6 Multi Media Amp Logo
168 people viewed this question
Top Integra Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
