SOURCE: Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
SOURCE: I have 33 gal craftsman 1.6 vertical air
Sounds like you do,but I would check the wires as well
SOURCE: My 33 gallon air compressor will at start build up
Most likely it is the unloader valve. This is inline with the air filltube from compressor to tank. Somestimes the unloader valve is screwed into the tank and air tube is attached to it. This device takes the pressure out of the tube so the compressor can start without the back pressure from in the tank. Other possibility, the start capacitors of the motor. The capacitors must give a kickstart upon startup or the motor will just hum for a couple seconds and overload the breaker. A tempoary solution is to turn off the power to compressor when it reaches 120psi, then allow the pressure to drop to 40 or less, then turn power on and mostlikey compressor will start with a load of 40psi or less. It is a nuisance but it works until you replace the bad part. Goodluck,Macgivor
SOURCE: Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
