Question about Dell Inspiron 1501 Notebook
My dell latitude d510 is not charging and i the icon is not on it
Posted by stacyannwalker on
Fox Mully
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Take the battery out and wait a few minutes. Then place it back in and see if the light to the battery charging indicator goes on.
Check the plug that goes into the laptop from the charger. Look to see if it's frayed or has exposed parts. My need a new charger.
Posted on Nov 25, 2014
5 Related Answers
SOURCE: need system unlock code for dell latitude
do you have the customber number or invoice number for the product?
Posted on Apr 07, 2008
Anonymous
SOURCE: Dell Latitude D510 will not charge battery
HI, check soldering on Fuse 1 right next to the power inlet plug, just fixed mine.
you will have to dissassemble it completly to get acces to it
Posted on Feb 13, 2009
Anonymous
  • 33 Answers
SOURCE: Dell Latitude D510 Screen Failed
The 14.1" inch screen is compatible with Latitude models D500, D505, D510, D600, D610 and Inspiron models 500m, 510m, 600m.
You may also need a screen inverter - in fact that is often the reason a screen is considered to be failing. The lcd inverter can be one of the most common items to become defective in a laptop computer. You may need a lcd inverter replacement if your screen is dim, dark, colored oddly, blinking, flickering or has dark stripes. Just something to keep in mind.
Hope this helps,
Chris
Posted on Mar 23, 2009
Anonymous
  • 56 Answers
SOURCE: how do you reset to factory settings on a Dell
Only way to do this would be to do a "system restore" without disks you can only hope you have restore points setup... run system restore from control panel and find out..
if no restore points contact dell for a restore disk.. remember the system restore without disks will not remove viruses or other harmful files..
Posted on Aug 30, 2009
Mohamed Omran
  • 2567 Answers
SOURCE: can i have the network controller, pci modem &
The drivers you are looking for could be found at the following link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=LATITUDE%20D510&os=WW1&osl=en&catid=&impid=
The drivers are arranged into categories for ease of browsing.
The drivers for the network controller could be found under "Network", PCI modem drivers under "Communication", & video controller drivers under "Video".
Posted on Dec 05, 2009
Latitude 510 battery light flashing amber and white
Hello, the problem you are having is caused by a loose connection on your motherboard between the charging port and the motherboard. You can either open your computer and try to solder it, or you will need to replace the motherboard.
Another possible cause is that your laptop charger is dead. If you can't confirm, just get a new ac adapter, it is much cheaper than replacing the motherboard:
Replacement Dell Latitude D510 AC Adapter 90Watt 19.5V 4.62A
Replacement Dell Latitude D510 AC Adapter 65Watt 19.5V 3.34A
Nov 11, 2012 | Dell Latitude D510 Notebook
The indicator light wont light up when i try charging my dell latitude d510 is there anyway to fix the transformer without buying a new one
No! the power supply is sealed, go to www.ebay.com Type make and model of laptop, refine search to power supply, and go through the list, you find pricing is reasonable.
Jul 04, 2012 | Dell Latitude D510 Notebook
Dell latitude d510 want power on
Why can't you dell latitude d510 power on?You didn't descript your dell latitude d510 problem clear even.It may be the problem of ram,graphics card ,mainboard,or dell latitude d510 battery.
May 31, 2010 | Dell Latitude D510 Notebook
I have a dell D510 latitude. AC power OK - doesn't charge battery
The battery of the dell D510 latitude is completely bad and need to be replaced. i suggest you get another one and avoid the battery running completely down before charging it.
Compliments and I wish you best of luck
Dec 24, 2009 | Dell Latitude D510 Notebook
Dell latitude d510 new battery wont charge
the laptop charger is the problem, try to fix it if you can or buy a new one with warranty..
Sep 28, 2009 | Dell Latitude D510 Notebook
Jan 20, 2009 | Dell Latitude D510 Notebook
Dell Inspiron 1501 Notebook Logo
42 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
