Question about Lenovo 3000 N500 Notebook
Mouse is not responding at all
The touchpad mouse does absolutely nothing How can i unlock the touch pad mouse on my laptop?
Posted by Alujan on
Anonymous
    Scholar:
  • 58 Answers
You need to go to device manager...
right click "my Computer"
select "manage"
select "device manager"
click the + sign for "mice and other pointing devices"
select your touch pad...
try to enable it or find what is wrong from there
You'll need a USB mouse or something of that ilk to do it.
good luck
Posted on Apr 10, 2009
Acer mouse disassemble ???
The Acer Aspire is a laptop model that has a built-in "mouse pad," also called a "touchpad." The user runs his or her finger across the mouse panel to move the cursor. If your mouse pad no longer responds to your touch, it may be due to a build-up of dirt and grease. Another common problem is having an outdated or damaged mouse pad driver. These problems can be quickly resolved without having to take apart the laptop.
Hold down the "Fn" key, which is found at the bottom left corner of the keyboard. Press the "F7" key once while holding the "Fn" key. Look for a message that says "touchpad enabled." b> Update the Drivers Go to "Start" > "Control Panel" > "System and Maintenance" > "Device Manager." Double-click on "Mice and other pointing devices" to expand the options. Right-click "Synaptics Touchpad" and then click "Search automatically for updated driver software." Wait for the computer to scan and install new drivers. Restart your laptop.
http://www.youtube.com/watch?v=oUyxhcQk6G4 Acer Aspire 5738 7736 Touchpad Mouse Replacement
Jan 30, 2013 | Acer Computers & Internet
Laptop Touch Pad will not work
if you plug usb keyboard onto your laptop it will probably turn the touch pad off.
If no other keyboard is attached there is usually a switch to turn off the touch pad.
also if you attach a mouse this may disable the touchpad so you dont move the mouse pointer when you are typing
Jul 10, 2010 | Acer Aspire One PC Notebook
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
My touchpad mouse won't work. it does not respond
If you are using XP, check your mouse settings under Control Panel. Make sure that your Touch Pad is enabled. If it is but it still won't work, have a mouse plugged into a USB port that will work correctly. Then download the latest driver from the Acer site for your touchpad. Uninstall the driver that is currently being used by your system. Then install the updated driver that you downloaded. This should allow you to use your Touch Pad. If not, you may have to take your laptop in for servicing.
Jul 15, 2009 | Acer Aspire One PC Notebook
Touchpad is not working
You didn't mention an OS but the following is for Windows:
You may want to reinstall the touchpad driver for your unit. You may also want to check whether the touchpad is enabled under the mouse settings. Good luck!
Feb 24, 2009 | ASUS Computers & Internet
try checking your function key on your laptop and try pressing Fn and the key that corresponds to touchpad to unlock it..
Feb 20, 2009 | HP Pavilion n3290 Notebook
Lapptop touch pad not responsive
there is an option to enable/diable touch pad by clicking combination of fun+f5 or f6 or enable it from setup.
Oct 21, 2008 | Computers & Internet
Lenovo 3000 N500 Notebook Logo
886 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
