The amp turns on but i cannot get the subs to work. what would be the best way to get all the power out of this set up? thanks matt
Hello manbearpig65,
Well, that's a 2-channel amp, so it's really best used to power a set of regular speakers.
The best power solution, for your existing components, is to wire each of your subs voice coils in parallel, resulting in a 2 ohm load, and then run each sub off a separate channel from the amp.
The amp is stable only to 4 ohms in bridged mode, so you would series the sub voice coils (8 ohm load) and then parallel them (4 ohm load) to the amp bridged connection. This will result in less power to each sub than if you ran them separately.
Hope this helps.
