Question about Kodak Easyshare G600 (1633379) Dock / Cradle
Charge batteries while camera is docked
I have a Kodak G600. I can't figure out how to charge my rechargeable Kodak batteries using the G600. When the camera, with the batteries in it, is docked, shouldn't the little battery light on the dock light up so you know it is charging?
Posted by w_sharp on
Anonymous
  • 34 Answers
What is the model of your camera and what specific battery are you using( what is on the label of the battery?)
when the camera is docked on the printer, you should get a little light indicating the charging status. Once it is fully charged, all 3 green lights would come on.
But, we need to know what is the model of your camera and what type of batteries are being used in order to determine if they are compatible or not.
Posted on Jun 30, 2009
I got a dx4530 w/easyshare Dock II. from a friend of mine. He had been using AA batteries and it worked fine. I went to Best Buy and bought 2 Ni-MH batteries and put them in the camera. I then put the...
In the Kodak cameras of that vintage the original 3V rechargeable battery was made of 2 regular AA rechargeable batteries and a special piece of plastic that pushes some microswitch in the battery compartment. If this piece of plastic is missing, the dock would not charge the batteries. You either need the special CRV3 battery or to charge the normal AA rechargeables with a separate charger.
Sep 18, 2011 | Kodak EasyShare DX4530 Digital Camera
My Kodak easy share is 5 yrs old. can I charge it without the printer dock as I want to take it overseas?
Depending on which camera model you have, you can use regular (lithium!) AA batteries in these cameras, no need to buy the specialty 2-battery rechargeable pack and use the printer dock to charge. You can go with regular NiMH rechargeable batteries as well.
Mar 10, 2011 | Kodak Cameras
Batteries will not recharge on Kodak EasyShareDX4330 Camera dock seems to be working fine otherwise.
if your are using the ordinary AA rechargeable battery it will not charge., Camera dock will charge only on a 2 Pack AA battery like KAA2HR batteries or the 2 AA battery that attached together (Ni-MH rechargeable battery pack )
What type of battery are using?
try to purchased KAA2HR
Nov 05, 2009 | Kodak EasyShare DX4330 Digital Camera
My Kodak G600 printer dock will not recharge my Ni-MH batteries.
you're right. You only can charge the Orginal KAA2HR batterypack of kodak in the cameras.
Aug 26, 2009 | Kodak Easyshare G600 (1633379) Dock /...
My G600 printer dock does not charge my rechargeable batteries
are you using a D26 adapater?
can you verify what type of batteries are installed in the camera?
The only battery that the dock will charge in the CX7530 camera is the
KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR
8156572
May 03, 2009 | Kodak Easyshare G600 (1633379) Dock /...
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
Recharge batteries in camera on g610 printer dock?
Hi, I think I can answer your question, i just tried something with my camera and camera dock.
My camera came with a Kodak battery pack(pack that looks like 2 batteries connected together). When I place my camera with this battery pack in it on the dock, a green light comes on on the dock and the batteries begin to charge. However, when i place any other rechargeable batteries in the camera on the dock, it has no effect, my theory is that it must be a battery pack, possibly by the same manufacturer so that it will charge correctly
Dec 20, 2008 | Kodak EasyShare C613 Digital Camera
Won't hold a charge
what rechargeable batteries are you using and what's your method of charging?
If your using a dock for charging - make sure you have the battery pack kodak kaa2hr otherwise the dock won't charge it
if you're using a separate charger - it's ok to use other AA ni-mh
please check the age of your batteries as well.. batts, even rechargeable eventually wear out - they can last up to 300 charging cycles and a year or a little more than that is enough for you consider buying a new set
if you say that you barely use the cam, batteries still deteriorate through time
Apr 12, 2008 | Kodak EasyShare CX7525 Digital Camera
Batteries
The only type of batteries that will recharge on the printer dock are kodak rechargables. Just place the camera on the dock and leave it. It should begin charging on its own.
Mar 28, 2007 | Kodak EasyShare Z650 Digital Camera
Kodak Easyshare G600 (1633379) Dock / Cradle Logo
Top Kodak Cameras Experts
Steven Wander
Steven Wander
Are you a Kodak Camera Expert? Answer questions, earn points and help others
