Question about HP Photosmart C5180 All-In-One InkJet Printer
Ink system failure - HP Photosmart C5180 All-In-One InkJet Printer
Posted by ddddd on
Rod Eslinger
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • HP Expert
  • 307 Answers
In most cases when the HP02 cartridge is not recognized, or has poor connectivity, you will normally receive an "Unrecognized Cartridge" or "Cartridge Problem" error message with a big RED X; in most cases (like 99.3%) the smart chip needs to be replaced with a new one - please note the chip life has 25 month expiration window from the time the HP02 (or 363 in the UK) cartridge is initially installed into the printer. Click here for more information when using refilled ink cartridges or general printing problems using any HP02 ink cartridge: http://inkjet411.com/?page_id=1372
Now, if you observe an INK SYSTEM FAILURE message then the permanent PRINTHEAD may be electrically damaged (unfortunately it is not replaceable; you can verify this by performing the following):
To bypass INK SYSTEM FAILURE message please see the HP Printer Diagnostics Tests file (pdf) for instructions: http://inkjet411.com/?page_id=1813
Verify the permanent built-in PRINTHEADs electrical performance inside this legacy printer model by running the TAP 43 diagnostic test (either one of the procedures below applies to all printers which use HP02 or HP363 ink cartridges): For additional HP02 support information, please visit our HP02 system support page which includes videos of everything mentioned below: http://inkjet411.com/?page_id=1372
A.HP02 ink-series printers with KEYPAD (i.e. keypad numbers 1-9)
Tap 43 PRINTHEAD Health Diagnostics:
Video Procedure: http://inkjet411.com/?page_id=2391
    1.Press * and # keys simultaneously.
    2. "Enter Special Key Combo" will be displayed.
    3.Press 123 to display the 'Support/Service' menu.
    4.At 'Support/Service' menu, click the Right Arrow 3 times until Special Reports menu is displayed.
    5.Select Ok, then click Right Arrow 2 times until the 'print-mech button tap' menu is displayed.
    6.Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed. Use the Left Arrow if you need to decrease numerical count.
    7.Select Ok. The test page prints.
    8.Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced (if part is still available). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
    B.HP02 ink-series printer models that DO NOT HAVE a KEYPAD:
    Internal Test Print:
    1. Press the Menu button, press the Right Arrow button to select 'Tools', and then press 'OK'.
    2. Press the Right Arrow button several times to select 'Print Test Page', and then press 'OK'. The test page prints.
    Tap 43 PRINTHEAD Health Diagnostics - See Video Procedure: http://inkjet411.com/?page_id=2377
    1. Turn ON the printer.
    2. Press and Hold the "Print Photos" & "Red Eye Removal" buttons.
    3. Release both buttons.
    4. You will see a new screen that says, "Enter Special Key Combo"... The Key combo is: press and release in sequence the "Red Eye Removal", "Print Photos", and then "Red Eye Removal"
    5. Scroll through the menu by pressing the right arrow button until the display says 'Special Reports'.
    6. Select Ok, then press the arrow button until the 'print-mech button tap' menu is displayed.
    7. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed.
    8. Select Ok. The test page prints.
    9. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed (unfortunately the PRINTHEAD is not replaceable). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
    NOTE: Costco USA/Canada, Fry's Electronic's, Microelectronics (along with some Best Buy stores in Canada) provide a top-notch refilling/chip re-programming service today...check it out:
    http://www.costcoinkjetrefill.com/pricing
    For additional and advanced HP printer diagnostics, please visit: http://inkjet411.com/?page_id=1813
    To help solve other HP02 ink-series printer/printing related issues please visit http://www.inkjet411.com
Posted on Dec 04, 2013
Ink failure ink system failure error oxc 18a0001
The "ink system failure" error is caused by air in the ink feed tubes. We have 2 articles posted on our web site giving step by step guides to purging the air from the tubes and clearing the error. You can find the articles at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | HP Photosmart C8180 InkJet Printer
Ink system failure error Oxc18a0306
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure Error: 0x05d1281
Ink system failures is a very serious problem on HP printer systems. Ifyou have this problem you should be ready to replace your printer.However there are still troubleshooting steps that you can do to try toresolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 14, 2008 | HP Photosmart C7180 All-In-One InkJet...
Ink system failure
hp photosmart c7288 all-in-one
ink system has failed unable to copy receive faxes or print refer to printer documentation error oxc19a0002
Nov 25, 2008 | Office Equipment & Supplies
HP photosmart 6188 Ink Failiure System
Not sure how to help you. Ink failure I would think is cartridge failure. Are you original virgin cartridges or refills? I need the actual error message that the printer is giving.
Nov 14, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Ink system failure
You can find a reset for the HP ink system failure at: http://www.inkbank.com.au/webcontent21.htm
It is for HP C7180 model, but might work with yours too...
cheers L.C.
Mar 13, 2008 | HP Photosmart 8250 InkJet Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
110 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
