Question about RCA DRD430RG DirecTV DTV Receiver
Universal remote control CODE for starsat receiver 150D
I want to use NEWSAR univarsal remote control model 96-1009 with my Starsat recever Model 150D. I need the 3 digit CODE to programe that????
thanks,
Posted by arabdulrahma on
  • Anonymous Apr 11, 2009
  • Anonymous Mar 17, 2014
    Without cable , it turned on, just when plugging cable it turned off!
Anonymous
    New Friend:
I have star sat remote sr x5100 plus. i want code to buy a new remote control
Posted on Oct 17, 2010
I HAVE A TECHNIK RECEVER WOULD YOU HAVE A REMOTE FOR IT?
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too.
http://electro-medical.blogspot.com/
Mar 09, 2014 | Televison & Video
I need the 3 digit code for ge universal remote model RC24912-A for sony dvd player
Code lists and manuals for GE remotes are available from http://www.jascoproducts.com/support/universal-remote-codes.asp . The 3-digit code list is here: http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit.pdf . The Sony DVD player codes to try are 166, 320, 321, 322, 361, 389, 399, 909 . (Sony DVD recorders may use 302, 321, 322.)
However, the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your DVD player is newer than your remote, you may need a newer universal remote.
I hope this helps.
Jul 24, 2011 | Universal Remote Control GE174Universal...
I need to set a 'One For All' Remote control,and I need the 3 digit product code, so I can make the control work.. The model # is VR5000A Thank You
One For All remote manuals and code lists are available here: http://www.oneforall.com/support/manual . Which specific remote do you have?
Most of the One-For-All remotes use a 4 digit code. The only one, URC-2005, that has 3 digit codes (of the ones I located) gives Orion VCR codes of 036, 088, 121, 208, 209 .
Note: remotes are limited to having codes for devices released at least 6 months before the remote was programmed. If your VCR is newer than the remote, you may need a new remote.
I hope this helps.
Jun 22, 2011 | Orion VR213 VHS VCR
I need the 3 digit device code for Zenith TV Model Z19A11S, to program universal remote.
Hi mwhaken,
You didn't mentioned the brand and model of your remote control, anyway you may try the code below.
ZENITH Codes: 000/ 001/ 004/ 023/ 038/ 058/ 059/ 064/ 121/ 135/ 136/ 153
Let me know the brand and model of the remote if the codes above does not compatible with the unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 09, 2011 | Zenith Z19A11S TV
Bought a rca universal remote. want to use with my emerson tv.model #ewt1921 cant seem to program a code that will work. br
HI,
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Sep 13, 2010 | RCA 257003 Remote Control
What is the code of the rca univarsal remote control for phillips tv
To get the code please go to below website
http://remotefinder.rca.com/default.aspx?site=rca
Please
Provide model of your remote
device to be programmed (VCR,TV)
Make name(toshiba,sony)
Thanx
Jul 29, 2010 | RCA Universal Remote Control
TEAC color tv model eu-80st
Different brand universal remotes have different codes. It really depends on what universal you are trying to program. In other words there is no set code for a certain model of TV. What brand and model of universal are you trying to program? Thanks for using fixya. I am here to help:)
Nov 05, 2009 | Televison & Video
Universal Remote iwave
I Have The Codes,But No instructions!! Big IWave . 0054-Philips Hitachi-0145 JVC-0053 LG- 0178 OR 1265
Jun 09, 2008 | Hitachi 50HDA39 50 in. Plasma HDTV
RCA DRD430RG DirecTV DTV Receiver Logo
2,960 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
