Question about Dryers
Dryer heats for only !st few mins.
I recently had the Thermostat replaced but, heat problem still exists. Dryer starts out with heat but, after a few minutes it goes cold. It takes 2-3 cycles for a normal size load to dry.
Posted by vgemmell on
Patricia Mitchell
  • 41 Answers
You didn't say if it was gas or electric. ?
Posted on Oct 19, 2013
Anonymous
    Problem Solver:
  • 17 Answers
There are different temp setting Thermostat ,check to make sure the right one was installed. recheck element continuity
Posted on Apr 10, 2009
Dryer does not heat correctly code F31
The thermostat which is a round 2 wire control on the blower box on the back of the dryer controls the heat on all dryers. always shut off power when checking any electrical appliance. Clothes dryers are wired with 2 voltages, The 240 volt supply is for the heating element only, while the 120 volt supply gives power to the timer and motor that spins the drum and powers any lights and switches. If the heating element is coming on, try replacing the thermostat. As always unplug the dryer first.
Dec 05, 2013 | Kenmore Dryers
Dryer won't heat. How can I keep troubleshooting?
You may have to get a new heating element when they go out the jet dryer where the heat comes out will not work normally this is caused buy a bad heat element. If not take back panel off and check the little white fuse and replace it, Almost all dryers are the same in that area.. Hope that helps....
May 15, 2017 | Kenmore Dryers
Dryer only heats for a few seconds at a time will not dryer clothes
Thermostat maybe? The fact that it is heating would indicate that all the circuits are good. I am thinking you damaged the thermostat - the metal expands with heat which breaks the contact and when it cools the metal flattens out to make a closed circuit - turning on the heat which then heats the metal and once again expands making the metal curve away to open the circuit,
Feb 02, 2013 | Whirlpool Dryers
Kenmore dryer not heating replaced element
You need to test the thermal overload, When elements go they can damage the overloads, You can do it easily with a multimeter and they are not expensive to replace. There may be one or 2 of them and can be found inline with the element wiring.
Mar 06, 2012 | Kenmore Dryers
Whirlpool Gas Dryer Model #LGR7648KQ0 has no heat - I cleaned out the vent (it was pretty well clogged!) and then replaced the Fixed highlimit thermostat, the thermal fuse and the dryer cycling thermostat...
The problem is the dryer coils are failing. They tend to fail as they heat up. There is a video at http://appliancehelponline.com/gdryertroublevideo.html this will walk you thru checking them. They are inexpensive and easy to replace.
May 26, 2010 | Whirlpool Dryers
Dryer Heats for 30 Minutes then stops heating
Hello there :
what you are going to want to do is to troubleshoot the heating circuit
if you have a multimeter
there is a thermal Cut-Out switch that is connected to the heater box.) -simply unplug wires and take reading from the end connetors
your reading should be 0 ohms. and nothing else
Next check
a part called the Hi-Limit Thermostat that is connected to the heater box, it should be located closest to the heating element wire leads unplug the wires and take the reading across the 2 wire connections . this should give you a reading of 0 ohms and nothing else.
Now if any of these 2 parts are not in this range they need to be replaced and i would recommend that you replace them as a set cause if one usually goes out then the other one will soon follow ok
I hope this is very helpful for you
Best regards Michael
Jan 09, 2010 | Kenmore Dryers
Kenmore Dryer 110.64632300 won't heat up!
vent pipe kinked not letting heat away from dryer, check vent , or the thermostt stuck and not cycling heating element cycle off
Aug 12, 2009 | Kenmore 63942 Dryer
Whirlpool gas dryer. Only few min.( less than 5min) heat work.
there is a thermal fuse inside the dryer it is a one time fuse also there is an ignitor that could be bad
Jul 03, 2009 | Whirlpool WGD5300S Dryer
Kenmore Dryer blowing thermostats.
your vent is holding heat and it cause it to burn out and also check the element itself
Dec 01, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
124 people viewed this question
Top Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
