Question about InFocus Projector Lamp for IN24+, IN26+
SOURCE: infocus IN24 lamp not lighting up
MAKE SURE BLUB WIRING IS THE SAME AS OLD BLUB, IN24 AND IN24+ WIRING IS DIFFERENT IN CONNECTOR.
Posted on May 06, 2009
SOURCE: replace bulb in housing for Infocus IN24
1 Turn off the projector and unplug the power cord. 2 Wait 60 minutes to allow the projector to cool thoroughly. 3 Turn the projector upside down on a soft cloth so that the lamp door is facing you. 4 Slide the lamp door off. WARNING: Be extremely careful when removing the lamp housing. In the unlikely event that the bulb ruptures, small glass fragments may be generated. The lamp housing is designed to contain these fragments, but use caution when removing the lamp housing. Before replacing the lamp, clean the lamp compartment and dispose of cleaning materials. Wash hands after lamp replacement. Hg ? Lamp contains mercury. Manage in accordance with local disposal laws. 5 Detach the lamp connector from the projector by depressing the locking tab on the connector and lightly pulling it free. 6 Loosen the captive screw that attaches the lamp housing to the projector.Carefully remove the lamp housing. Dispose of the lamp in an environmentally proper manner. 7 Install the new lamp housing and tighten the screw. 8 Re-attach the lamp connector to the projector. The locking tab should engage when the connector is fully plugged in. 9 Replace the lamp door by sliding it into place. Be sure the lamp connector wires are not in the way. 10 Plug in the power cord and press the Power button to turn the projector back on. 11To reset the lamp hour timer, navigate to the Settings>Service menu and select Reset Lamp Hours.
Posted on Nov 12, 2009
SOURCE: can the filter be changed on an InFocus IN24
there are no replaceable filters. just blow the dust out of the projector with canned air
Posted on Dec 03, 2009
Jun 04, 2014 | InFocus Office Equipment & Supplies
Mar 08, 2011 | InFocus IN24 Multimedia Projector
Jan 16, 2011 | InFocus Work Big IN24 DLP Projector
Oct 24, 2010 | InFocus IN24 Multimedia Projector
May 17, 2010 | InFocus IN24 Multimedia Projector
Mar 08, 2010 | InFocus IN24 Multimedia Projector
Mar 20, 2009 | InFocus Projector Lamp for IN24+, IN26+
Jan 14, 2008 | ASK Proxima Proxima DP2000S Data Video...
May 16, 2007 | InFocus LP330 and LP335 Replacement...
Oct 07, 2013 | InFocus Projector Lamp for IN24+, IN26+
Jan 22, 2018 | InFocus Projector Lamp for IN24+, IN26+
59 people viewed this question
