Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Not enough hot water
Tank is 10 years old. only have a 10 minute supply of hot water for showers, used to have about 45 minutes. Have replaced both elements and the upper thermostat. checking the power distro has shown that there is power being applied to the upper element, but no power is going to the lower. I checked the power going out to the lower thermo from the upper thermostat.
Rheem model 59T Electric Heater Model# 71-52D
Posted by 165grnosler on
  • 1 more comment
  • 165grnosler Apr 09, 2009
    Nevermind! I was not patient. Searched this site and found the answer concerning the top element heating first then applying power to the bottom. Went back over to the heater and darn if that wasn't it. tank works fine. Thanks.
  • Anonymous Mar 16, 2014
    This problem started from installation, 1year and 2months now. Can a heater tank be faulty. need to know my Job in riding on getting this resolve.240volts/4500watts dual element thermostat set at between 120F and 150F
  • Anonymous Mar 30, 2014
    Vanguard 50 gal electric hot water heater Model #3WA73 - Serial #VG1207023557 - Wattage 240/208 Volts - Upper 4500/3380 - Lower 4500/3380
Donni Steen
  • 687 Answers
Makes you feel good to save some money right? Have a great day!
Posted on Apr 10, 2009
Why does the water suddenly runs COLD after many minutes of running hot?
Unless you are using a tankless hot water heater, there is a limited amount of hot water available in the tank. Electric and gas water tanks need time to recover after use, and if you are using heavily, it can exhaust the available supply. That said, there are a couple reasons why you may have less hot water than seems normal. In both electric and gas water heaters, silt can form in the bottom of the tank. This will build up over time and displace water. It also reduces the heating efficiency of gas units. There is a drain valve on the bottom of water heater tanks to allow for purging of this silt periodically, but few ever do it. You could also have, in the case of an electric hot water heater, a bad element or thermostat. Most electric heaters have an upper and lower element and thermostat. If one fails the other will still work, but the water takes longer to get hot and will deplete faster.
Nov 04, 2015 | Water Water Heaters
Yesterday the hot water went cold after 2 minutes into a shower.I checkAQed the hot water unit and noticed it seems to be damp around the base.it's an Aquamax 315 twin element electric hot water heate
Electric hot water heaters are particular to water levels and air pockets. Air pockets (low water levels) can cause the upper element to fail thereby reducing the overall recovery of hot water. Also if this is supplied by a well the incoming water temperature is lower than city water and also maybe adding to your problem. First thing I would check is the upper element. Start there and re-post with updates..
Sep 30, 2014 | Water Heaters
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 25, 2012 | Rheem Water Heaters
How long does the model 81v52d last in years?
Did you clean sediment out of tank when replacing elements?
Did you replace thermostats? Thermostats go bad, or get out of calibration.
Test elements.
Sounds like lower element is burned out.
Clean sediment out of tank. Check for water leak running hot water out of tank by putting ear against pipe.
Electric water heater will last 20+ years, IF ...
Electric water heater is totally unique because it can last forever with part replacement using parts from hardware store, as long as tank does not rust because of depleted anode rod, and pressure is kept below 80psi.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Annual water heater maintenance will pay you $10 a month, tax free money in pocket, by avoiding tank replacement.
Nov 25, 2012 | Water Heaters
Got 5 minutes of hot water then cold. replaced both elements and thermos. still 5 minutes of hot water. power bill increased nearly 400% in 30 days. HELP!!! please.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced. You replaced both elements however check that the lower element is coming on after ther upper one cuts out and is acutally working.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, maybe defective. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
If the dip tube is broken, the incoming cold liquid can mix with the out going hot liquid and cause it to seem as though you are running out.
Nov 04, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
I have a Rheem Model # 62SV-520 and I loose hot water after about 10 minutes in the shower. I think one of the heating elements is bad, but if so, which one.
There performance depends on your demand. If you are using an energy saving shower head I would expect you to have enough hot water for easily a couple of showers. But, if your using the "power flush" type shower heads that use 3.5 gpm or more, the 40 gallon heater is not enough. Also, consider type of water your heating. Is it well water or municipal. Unsoftened well (this includes some municipal well supplies too) water causes hardness ions to cake the heater element making them less efficient. If you have the low flow shower, it is likely you have an element burt out. They can simply be replaced and picked up at any big box store for less than $20 dollars. Each element can be tested in place with a continuity tester. If your not sure how to test, but would be willing to replace the elements - replace both of them. You will have to shut off power to heater and drain tank completely before removing elements. Replace elements with same wattage or higher. Most have two 2250 watt elements for a total of 4500 watts. you can easily install two 3000 watt elements and have a quicker recovery rate and more hot water than ever.
Jan 03, 2011 | Rheem 81VP6S/430126 Water Heater
Hot water does not last long. Model 82vh40-2 mnf. 05/2005
If the lower heating element burns out the upper element will heat the top part of the tank then shutoff. homw depot/lowes etc should carry elements. 1 turn off breaker, remove element access cover (the 2 panels on the front of the heater) test for electricity at the reset button ( uppermost device in upper panel) to make sure power is off. 2 turn off water (I usually turn off the cold water main to stop water cross feeding into hot supply line back into heater) 3 disconnect the 2 wires on the lower element, test with continuity tester. shhould be no continuity between terminals and tank, but around 10 ohms between the 2 terminals. Check the thermostat for continuity if tank is cold thermostat should be closed ie zero ohms across the 2 terminals.
If stat is bad replace stat; disconnect wires push it up out of the spring clip insert new stat reconnect. If element is bad: drain tank. connect garden hose to tank drain valve, open tank drain valve turn water main on to clear rust sediment and get water flowing. Next remove filter screen from a hot water faucet then turn on ( a hot faucet upstairs or higher than tank drain). Now turn water main off, air will now go in through hot faucet and tank will drain, takes about an hour. Use a water heater element wrench about$10 to remove element(s) make sure no bits of rubber gasket are left in element opening- dig em out with a screwdriver if needed. Insert new element with its gasket and tighten. reconnect wires DO NOT TURN ON ELECTRICITY! BE SURE TO FILL WATER HEATER WITH WATER ! Turn water main back on -air will come out of the hot faucet for several minutes. When water runs without any air sputtering, turn off faucet and replace the faucet filter screen. check element(s) for leaks. turn breaker back on.
Feb 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
618 people viewed this question
Top Rheem Water Heaters Experts
Bill Johnson
jdthefixer
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
