Ovens Logo
A
Anonymous Posted on Aug 23, 2013
Model kesk901swh00 has error 30 on display - KitchenAid Ovens
1helpful
2answers
Frigidaire oven fpcf3091lf code eo90 comes on and beeps goes away but comes back.happened after power was out for a while
Frigidaire FPCF3091LF Complete Owner Guide English Page 30
click on the link above and check on page 30 on Setting Oven Controls
https://www.manualowl.com/m/Frigidaire/FPCF3091LF/Manual/173714?page=30
To restore all user settings to factory default:
step
1. press and hold 7 until first beep sounds
2. press start
1helpful
Frigidaire stove error code
F68 = Power Line Failure. Turn power off for 30 seconds. If this does not correct it, check the electrical supply for proper voltage, ground, and polarity, if all of this checks ok replace the EOC-Display board
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
2helpful
Digital display is reading F10 and beeping and the oven shuts off after burning Banana Bread I also had smoke coming out the back panel of the stove top
The F10 error code means that a button on the touchpad is stuck.The error code can be cleared by pushing the cancel/off button and if the F10 returns the clock needs to be replaced since on that model the touchpad is part of the clock.
GENE
1helpful
2answers
We turn oven on to heat and get E2 error code and then F1 error code where cook time should be displayed
Hi dear.Here is what you can do: F1 - E2
UL A/D error(s)
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
I hope that helps.Thanks
I have a Kenmore 30" double wall oven model no. 911-41185. It will not let me do anything and keeps displaying FO and beeping. Can you tell me what is wrong?
F0 means no error. press cancel to clear display.
If you cannot then that key might be stuck, just a guess. I have your tech repair manual with failure codes and troubleshooting on page 43. This NOT a user guide. It is meant for qualified peeps. So be careful. Late model double oven tech repair manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 06, 2010 • Ovens
Whirlpool model: rf385pxdz My oven will not work, First It displays "door" then displays error code "EO F7"
Hi. This is a possible control board issue. First i would advise to check the wiring at the door switch mechanism, and control. Make sure the wires that link the control to the actual door latch assembly, are connected well, and are not lose. If the wires are Ok, and not corroded, simply replace the main control board.
1helpful
Self cleaning oven an f1 error appears
Analog to Digital Failure
Disconnect for 30 seconds - if display reappears - replace control board
Whirlpool Oven Model RF365PXGN getting a error of F1 and E2
HELLO, I HAD THE SAME PROBLEM. ALL YOU HAVE TO DO IS FIND YOUR CIRCUIT BREAKER BOX AND LOOK IN IT FOR THE BUTTON THAT SAYS KITCHEN. TURN THE KITCHEN POWER OFF FOR 30 MINUTES THEN TURN IT BACK ON. ONCE YOU TURN IT BACK ON THE OVEN SHOULD RESET ITS SELF. TRY THAT AND IT SHOULD HELP.
Oct 31, 2008 • Ovens
Oven does mot work
F-7 on the GE is a touch pad error, all you can do is replace the whole touchpad. You can try shutting the power off at the breaker leave off for 5 min at least. turn the power back on sometimes this will get rid of it for a time.
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Top KitchenAid Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
