The cold water barely comes in the machine. The warm water comes in fine, but the cold is just a small stream of water. We have checked the supply lines to the machine and they are new and water flowing out of them fine. We do not have water pressure problems anywhere else in the house.
Brushing,
There's a chance that the screens on your inlet valve have gotten clogged. Turn the water off and remove the hoses from your inlet valve on the washer. Inspect the screens there... if they're clogged that's your fix! Clean them out and you're good.
If the screens are clean, that means that your water valve has gone to appliance parts heaven and should be replaced. Watch this video to learn how to gain access to your machine...
The valve you'll need is part number 285805 and it's a breeze to replace. After you have the cabinet off, you'll see it on the right side of the rear panel.
If you have any further questions or if I can help in any other way, just write back.
Don't forget to rate this solution!
SG
