Washing Machines Logo
Question about Electrolux Washing Machines
Electrolux ewf1074 error e40
When I set the washing machine to go it makes a clicking sound then shows E40 flashing on the screen. Do you know what this error is, I have packed my manual away in storage!!
Posted by occtodecor8 on
  • jc070369 Sep 13, 2009
    Hi i have a problem with my Electrolux ewf 1090 i have don the 30minute quick wash then i put it on for the 10minute spin when i push the button to start the marchine it make this clicking noises 2 or3 times then it come up with the error message i have switched it on and off at the power point i do the same thing over again and i still get the error message E40 that is what come up in the display window can you help me.
Anonymous
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
Posted on May 10, 2009
Anonymous
    New Friend:
E40 ELECTROLUX error fixed
Just fixed one E40 problem on my EWT10420W. Electrical locking of the opening was burned a bit and the connector as well. I bought a new el. locking (146 117 404/5). The connector is not provided as spare part by the manufacturer so I cut out the original burned one and connected the cables one by one. To reach the electrical locking only two side panels of the machine must be removed.
Posted on Jun 25, 2013
1helpful
What does error E40 mean
Zanussi Washing Machine E40 Error Fault Code
Electrolux Time Manager How to Fix Error E40
E40 indicates a problem with the door lock circuit in the appliance.
It could be as simple as a faulty door lock or it can be a faulty main control board.
Hi my Electrolux EWF1074 isn't working. The timer is counting down but there is no water in the machine. I tried resetting it but it didn't work. Could someone please help me. Regards Matt.
Rapid reading of alarms:
Press the START/PAUSE button and the nearest option button (4) simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
ewf1074-2rgnvy5j4oifscmshudmmeh4-3-0.jpg After reading error code (look display) will be a lot clearer in which phase of the washing cycle has occurred or is happening malfunction.
New washing machine (electronic) compared to the old models (electromechanical) consume much less water, so it looks that your washing machine is working properly, otherwise it would be stopped. This will be confirmed if the display show E00 which means there is no any malfunction. Any other error code, for exp. E10,E20,E30, E40, E50...... means some malfunction.
Dado
Built in machine. It show error e40. What does it meant
Hello Monica, thank you for your post!
Based off the information you have provided your Electrolux washer is displaying an error code of ā€œE40ā€. I am showing that an ā€œE40ā€ error code means this could be an issue with your door swicth or main control board. I would recommend performing a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If you continue to receive the error code once power has been restored you may need to seek assistance from a professional technician for a proper diagnosis. Hopefully this information is helpful to you. –Matt
15helpful
3answers
Error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
15helpful
Error code e40 on my washing machine electrolux ewn 16781 w
The Error E40 warning means the door is not properly closed. The E40 error code indicates a loss of electrical power usually but not always due to the door not shutting properly or not locking. But, since you smelled burning it could be any electrical short that blew a fuse and shut the machine down. It could also be the motor windings with the internal overload protector shutting it down.
Thank you for contacting Fixya.com
4helpful
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
