Open bleeder valve and use a large c-clamp on back side of caliper and inside of brake shoe. Close bleeder valve when piston returns all the way home, then remove c-clamp. I've had a similar problem in the past...if you do not close bleeder valve before you remove c-clamp, you might introduce air into the brake system
When you reach the first stop on a saved route the satnav should automatically set the next stop as it's destination. If it doesn't it's possible that the spot you saved as your first stop was not exactly right i.e. you didn't drive to where it's marked on the satnav. If this is the case you need to mark the spot by driving to it and pressing the car (which shows your location on the satnav) and this gives you an option to save present location. Save it and use it instead of the one you entered by address. Then when you're setting your route you'll find it in your favourites and add it from there.
To get back to the map go back to the screen which shows WHERE TO and VIEW MAP. Press VIEW MAP and it will bring you back to your map and should continue with your route.
using your touch screen, go to tools> my data> set home location> you can use your current position or you can enter it. then it will be save as a home address
apparently your computer doesn't like Trainz 2006. lol. but anyway you should try to erase Trainz 2006, and reinstall it. And that should do the trick. If not, Install Trainz 2006 on another computer if another computer is available.
You should be able to just " change time 4" and then blank out all of the fields to return the form back to it's default and as long as you have not added that time of day route plan into any of your COR's then you should not have any issues with it.
