Question about Visual Land V-Bop MP3 Player
Mp3 player wont charge or turn on
The screen will turn on when i plug it into the usb port but it wont charge and it wont turn on when i unplug it from the usb
I have the vl 868 and it would only turn on with the charger in- not when it was unplugged. it took me awhile- you have to turn the switch on and then hold play for like 4-5 seconds for it to turn on.
Posted on Apr 21, 2009
Eclipse mp3 player 4g wont charge
Try this. Turn your computer off. Plug in the mp3 via usb port with player in the on postion. Turn the computer back on. You should a large green battery symbol on the screen flashing left to right. Took me about 3 days of finally fiqure it out. Also try different USB ports if you have more than one. Good Luck
May 04, 2012 | Mach Speed Eclipse 180 MP3 Player
I just purchased the MP3 player and can't use it yet, because it won't charge....I tried both USB plug in spots on the front and back of my computer tower and neither worked.
. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Apr 16, 2010 | SanDisk Sansa Clip MP3 Player
MY COBY MP3 WONT TURN ON EVEN AFTER CHARGING AND
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
Mar 27, 2010 | Audio Players & Recorders
MY MP3 DOESN'T CHARGE
Mar 19, 2010 | Digital Audio TRIO MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
Mp3 wont charge
Jan 02, 2010 | RCA M4304 Digital Media Player
MP3 WONT TURN ON
Oct 06, 2009 | RCA TH1611 MP3 Player
MP3 Player Not Charging!!! (USB)
on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
2. switch thje player on
Feb 15, 2009 | Coby MP-C7092 (2 GB) MP3 Player
My zen wont charge
It won't charge from an USB hub. It must be plugged intoan USB port on the computer itself.
Oct 29, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative zen v plus
You could try the back usb port, mine doesn't charge on the front port It needs 2.5vdc?
Aug 26, 2007 | Creative Labs ZEN V Plus MP3 Player
Visual Land V-Bop  MP3 Player Logo
512 people viewed this question
Top Visual Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Visual Audio Player and Recorder Expert? Answer questions, earn points and help others
