Minolta 2530DL. This piece of junk has another paper jam. I have followed all the instructions I can find on-line, but only have a couple of bits of torn paper in the roller/s, that I can't reach. How do I get at these bits, without damaging the roller beneath ? I won't be buying Minolta stuff again - their service department is ****.
Thank you for your kind reply.
I'm not going by the readout - but by the fact that bits of paper get stuck under one or two of the final feed rocker/rollers,,,, and are a bu@@er to get out.
Kinolta Customer Service - AND MANAGEMENT - are aware of just how badly designed this paper feed system is, but will do nothing about it.
I have had to virtually strip this piece of carp down, just to give me a little more access,,,, even then, its more than a struggle.
Thanks again.
SOURCE: My Konica Minolta 2530DL printer has paper jam ,as
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
