Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker is frozen in a kitchen aid side by side
Ice appears to be frozen in the ice maker
  • mkdog874 Apr 12, 2009
    the ice maker doesnt make ice. Everything else is working correctly.
  • Anonymous Apr 17, 2009
    Ice is "stuck" in the ice maker. Water dispenser works.
Try pouring HOT water into the ice molds to release the frozen cubes. Hopefully the ice maker will restart the cycle and get back to normal!
Posted on Apr 18, 2009
6ya staff
SOURCE:
GE Ice Maker freezing
Not sure exactly what you mean by the ice maker freezing, ice makers are suppose to freeze. But if you are referring to the ice maker not being able to harvest the ice since it is frozen in there to tight, then the heater that is on the bottom of the ice maker has failed and you will need to replace the ice maker.
Here is a link to the new ice maker.
Oct 15, 2012 | Refrigerators
Ice maker appears frozen.. last pieces of ice to come out were in frozen clumps. Now not doing anything
Need to defrost the freezer. The ice-maker water path sometimes freezes so it must be thawed out.
Jul 15, 2009 | Refrigerators
Ice maker not working
You will have to pull the ice maker out, defrost fridge or use a hair drier to defrost all parts in the freezer. then replace ice maker
Jan 21, 2009 | Sub-Zero 611 / O Bottom Freezer...
make sure the wire rod on the ice maker is in the down position in order for it to make and release the ice
Dec 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Ice maker not making ice
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker water line appears to be frozen on gd5sha. ice maker won't function.
thaw the whole refrigerator for a whole day to thaw the ice inside the water line. it will reset also the timing of the ice maker.
Jul 05, 2008 | Whirlpool Refrigerators
Ice maker jambed-now no water
The ice maker must be re-primed with water to sense frozen ice in the tray, dump, and refill. Use a cup or glass to manually pour the water into the tray just below the top of the blades. It should freeze, dump, and refill.
May 15, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker
check the fill cup on the back of the ice maker for an obstruction of frozen ice, it the fill cup is frozen over then the water entering the ice maker will cascade over the frozen ice down into the freezer
if frozen melt it with a hair dryer then it will be ok
Apr 20, 2008 | Maytag MZD2752G Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
388 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
