Kinderkraft Vermont Crib Logo
Question about Kinderkraft Vermont Crib
I need to fix dresser drawer on kinderkraft dresser. If weight was put on the drawer like my daughter standing in it the drawer tips out and wond close anymore. Does anyone know how to help?
1 Related Answer
Anonymous
  • 4 Answers
SOURCE: kinderkraft crib?????
Go to Products America's website: productsamerica.com. They have a 1-800 number you can call and they should be able to help you...
Posted on Jun 13, 2007
How to remove drawers from a legacy brand dresser
Pull the drawer out as far as it will go, then gently add more force and it will come the rest of the way. Be careful putting it back in because the plastic stop at the front end of the center slide is easily breakable.
1helpful
Can't remove drawers from Hayworth mirrored 4 drawer dresser
I'm not sure about the dresser drawers, but for the night stands and the armoire, pull the drawers all the way out. Feel under the drawer (towards the middle back), and there should be a plastic tab. Push the tab down toward the floor and pull the drawer at the same time. It should come right out.
AAmerica dresser drawers don't open all the way. How to remove the dresser drawers.
Try some lubrication on the sides of the drawers...may make it easier to slide out.
Can you remove the drawers? We need to move it upstairs, and it would me much easier without the drawers.
Try pulling the drawers out as far as they go, then put some lubrication where it's stuck and gently try and wiggle them out.
1helpful
Can't remove dresser drawers
on some dressers there is a little button under the draw in the center that you have to push in order to allow the drawer to come completely out
2helpful
Need instructions to put together Davinci Parker dresser. Item # 02f162, SKU:K5155F
Here is a link to download the instructions for the Million Dollar Baby DaVinci Paker dresser: Model K5155:
http://www.milliondollarbaby.com/system/pdfs/60/original/K5155_Parker_4_Drawer_Dresser_-_10.29.09_HS_.pdf?1256922917
Removing a dresser drawer from a Kinderkraft chaning table #225
There are two metal tabs above the gliding rails on each of the drawers. Push them downward on each side simultaneously when the drawer stops. You may have to do this twice for each drawer; KinderKraft probably put this in as a safety precaution because it is nursery furniture.
Kinderkraft crib?????
Top Kinderkraft Baby Gear Experts
Marvin
Marvin
ray gallant
ADMIN Andrew
ADMIN Andrew
Are you a Kinderkraft Baby Gear Expert? Answer questions, earn points and help others
